Chr0nik
- Dec 2, 2005
- TM-9100 Linux receiver / Edision OS mini 4K / TM-2600 M3 motor / 110cm dish (34.5w to 50e) - 100cm dish (51.5e/52e/53e/60e)
- Grays, Essex
I'm currently trying to get 28.2e/19.2e/13e/9e/4.8e connected to my box (Technomate 9100) using 2 4-way Diseqc switches. I've installed it the following way:
Switch 1:
1 - 28.2e
2 - 19.2.e
3 - 13e
4 - Diseqc switch no.2
Switch 2:
1 - 4.8e
2 - 9e
Receiver port - Diseqc switch no.1
The problem is that I can get the 28.2e/19.2e/13e/4.8e to work but no matter what configuration I try (1.0 / 1.1 / 1.2), I can't get 9e to work even through it works when I connect the lnb straight to the receiver. I have tried with a 8x1 switch and it's the same. What could be the problem & possible solution?
Thanks a lot!
Switch 1:
1 - 28.2e
2 - 19.2.e
3 - 13e
Switch 2:
1 - 4.8e
2 - 9e
Thanks a lot!
