DarkDeveloper
- Sep 30, 2005
- Age
- 49
- 1.2m Hotbird + 90cm Nilesat dishes. Comag SL100HD CI/MVision MV-9085 USB Net receivers, Windows 7 WMC PC with Pinnacle PCTV 3010x + FloppyDTV
- Middle East
I’m fairly new to this Sat TV/PC business and have searched the highways and byways of the forum to gen up on the subject.
I think I know what im doing ;), but would someone be kind enough to help fill in the gaps in my (current) knowledge?
Here we go….
1.
I’ve looked through the forums with regards to *cough* encryption *splutter* related plugins….. and noticed that they seem to require the use of three different plugins.
i.e. Install a viewer (ProgDVB / DVBDream etc.), a softkey and then one of three pieces of software:- S2emu, Vplug or Yankse/Fenrir
I notice that postings these days seem to relate more to S2emu and VPlug (I am assuming that Yankse is an older, more complicated, less popular method??)
Could anyone explain any differences between these different plugins and which is the preferred one? (S2emu seems the simpler, less configurable than VPlug…)
2.
My understanding of Sat encryption is that different channels use different encryption methods (Ireto?, Nagravision? Conax?)
Which channels/encryption methods do the above methods, erm, help with… (I notice Multivision, Private Spice etc often get a mention ;) ). Do I need different s*ftkeys for different encryption methods/channels? (My system points at Hotbird 1 – 5 & Nilesat)
3.
Related to Q2, when I visit a site such as d*b-upload, I get a long list of files with names like:-
T*s_bin 29_30.03.2007.zip
S*ftcam.Key S*xyView Update 29.03.07.zip
T*s.bin up to 30.03.07.zip
Tita1 N*gra2 update D_ 29.03.2007.zip
S*ftCam tps d_ tvcabo.zip
DVB-S Card_Key_Update_290307.zip
Etc.
What exactly am I looking for? I notice that the zips with s*ftcam in the title tend to contain the .key file I am looking for, but what about the rest? (tps.bin?)
4.
Finally, would someone be able help me put all this together?
This is what I understand and am doing so far….
I am using DVBDream, I put S2emu (1.26) and/or VPlug (1.6.2) into the Plugins\pip00 directory along with a .key file (Some of the .key files I have downloaded, I have had to rename to ‘s*ftcam.key’).
I run the ‘copy all plugins’ batch file (which seems to copy the .key file to the \Plugins directory) and then (with VPlug) I go into the VPlug editor and click ‘Select’, ‘Convert’ and finally ‘Update’
I go to some of the channels with the little red V against them (I’ve tried the often mentioned ones - Private Spice/SexyView) and…..get a blank screen….
I checked the .key file (downloaded from a link on d*bskystar.com) and noticed that it is dated 2006, so figure it must be out of date; hence I try some of the keys mentioned in Q3 – same result.
I think the problem may be I am using the wrong key (or clicking on the wrong channels) or the s*ftcam.key is out of date….
However I notice that a lot of the s*ftcam.key files (from d*b-upload) are dated the same day, but the early hours of the morning (i.e. 5am) – do these keys expire that quickly (in a matter of hours?)
Anyway, sorry for all the questions! Hope that someone doesn’t mind helping me out and thanks in advance!
Here we go….
1.
2.
3.
Etc.
4.
