• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
Angle Grinder - Component with three wires
Suffering fools just so you don't have to
Likes
4,839
UK South East
#1
Been given a 'dead' angle grinder, generic design with 10 inch disc.
I get continuity through the circuit, from plug up to switch and beyond, and from motor windings, through the brushes, back down.
It all stops at an unmarked lump with three wires. I assume it is a slow start device, delivering power progressively in relation to the disc momentum.
Its about an inch square and sits in the handle of the grinder.
Any idea what it is called and how to get a replacment ?
iwol
Likes
11
channel master 1.2m dish
technomate 6900,,and invacom 0.3 quad lnb
satlook micro
yorkshire
#2
its not the suppressor is it i cant see a generic grinder coming with a soft start
Likes
4,839
UK South East
#3
Would a supressor have three wires ?
Will try to get a picture in the next few minutes
mhku
Likes
19
TM Nano ~ sg2100
Midlands
#4
Is it a contact relay? There is a similar box in my coffee grinder described as
MAZ_40 - Mazzer Grinder 110V Voltage Contactor
Fits all Mazzer Super Jolly and Major Grinders, and allows use of lower amperage power switches. $70.84 View Details
and looks like this
Likes
4,839
UK South East
#5
Nah, this is a solid state thingy, all wires to it are sealed in the resin.
Lancelot
Likes
SS1.
36v H to H 62E - 61.5W
South central
#6
Where do the wires come from/go to CH ?
Might give a clue.
L.:)
Likes
4,839
UK South East
#7
Might give a clue.
L.:)
F*cksocks
Now I have taken the handle completely apart, it has markings.
XS-12/D3
which is a soft start device
http://www.chinapowertool.com/products/CompanySingleAccessoryProduct.asp?id=5387
Diagram embossed on heatsink is like this
__
l A l ------------------
l B l ------- M - ~
l l l
l C l------------------
l_l
Connections
Live from switch (red)
output to motor windings (blue)
third wire to switch (double pole) neutral (black)
Motor has direct path back to switch neutral , and there is a 0.33uF capacitor across the switch terminals
Where to get another one ?
Lancelot
Likes
SS1.
South central
#8
My first instinct would be to phone round local tool hire shops and see what they do. Might even have a 'dead pile' you could raid for a beer ??
L.:)
Likes
4,839
UK South East
#9
Ive gone back to the manufacturer and asked for a sample (I've offered to pay the freight ).
Likes
medion pc
uk
#10
it's the bridge, should have a DC regulater in there, have a look to see if any components are burnt, and check very carefully to see if the triac leads or heatsink are connected, most likely cause of failure
Likes
2,983
--------See sig--------
#11
Unfortunately the post is over a year and a half old.
I'm sure that even Channel Hopper will have given up and thrown it away by now if he didn't find the answer.
Likes
4,839
UK South East
#12
I never throw things away.
It was a soft start device and had no luck with the supplier, so I bypassed it.
I do have to hold on slightly more securely when starting it, but apart from that, no other real issues.
