Astra 2F: Pre-Operational Discussion
tothbros
Budapest, Hungary
ASTRA 2F Ku-band: Europe/UK 48
all ku bands transponders cover ANY PART of 10.7 to 12.75
out of the 48, do we know how many are UK and PE Beam?
i thought it was a fact that no tp's on 2F under 10.95 GHz...sometimes I get lost between fact and fiction here :)
Oh, there's plenty of fiction ..................
mbsnr
Sky+ HD - FTA 43W to 42E
Ireland
From my reading, there were reports that no test freq's under 10.95 were seen when the sat was @ 43E. I'd find it incredibly strange if the sat did not have the ability to support the full freq range. So there's either an issue (which we are only guessing at) with the TPs from 10.7-10.9 or it's simply the lack of facts leading to fiction.... No one seeing those freq's during testing doesn't mean the capability isn't there.
easydigital
Sweden
Motorised 120cm dish,
VU+® Solo² Full HD 1080p Twin Linux PVR
VU+ UNO HD Receivers
Titanium Twin LNB TT 0.1dB
Inverto Black Ultra 0.2dB
Stockholm
ASTRA 2F SNR strong here in Stockholm, Sweden Beacon is on 11007MHz V with around 13.8dB
buckshee
So to simplify things a little, what are we expecting to change overnight:
11.023 H, SR 23.000 FEC 2/3 DVB-S2 *PSK "8901" and "8911" (BBC 1 HD's) already there
10.964 H SR 22.000 FEC 5/6 (CH5/5USA/5*/Channel 5+1),
10.994 H SR 22.000 FEC 5/6 (ITV 1 Granada HD/ITV 1 Central South West SD/ITV 1 Anglia West SD/ITV 1 Meridian North SD/ITV 1 Yorkshire East SD/ITV 1+1 Yorkshire SD),
11.052 H SR 22.000 FEC 5/6 (ITV 1 Central South SD/ITV 1 Central East SD/ITV 1+1 Wales SD/ITV 1+1 Westcountry SD/ITV 1+1 Tyne Tees SD),
11.126 V SR 22.000 FEC 5/6 (Channel 4 HD/4Seven SD)
ANY OTHERS ?
pe beam testing high signal 12425h and 11470h spot beam
same tp 2a low power
Mr Hoover
Various Receivers and Dishes
Portugal
12425 H spike in Portugal "looks" like the 2A/2B south beam level
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
Huevos said:
Frequencies reported in the testing thread (including band D):
http://www.satellites.co.uk/forums/topic/156363-astra-2f-testing-reception-reports/?hl=%20astra%20%20testing
10754V? 10806V 10840V 10870V 10953H 10986V
10991H 10964H 10996H 11000V 11030H 11050V 11055H 11075V
11076H 11080V 11118H 11120V 11161V 11180V 11193H 11263V
11303V 11307H 11332H 11340H 11342V 11345H 11360V 11369V
11440V 11515H 11527V 11534H 11538V 11623H 11625V 11650V
11675H 11711H 11725V 11776H 11778V 11786H 11798H 11817V
11826V 11856V 11861V 11866V 11876H 12160H 12169H 12185H
12185V 12200H 12207V 12208H 12226H 12246V 12252V 12265H
12270H 12285V 12304H 12323V 12337H 12363V 12402V 12422H
12441V 12460H 12480V 12490H 12518H 12539H 12551H 12580V
12580H 12590V 12725H
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
ANY OTHERS ?
im expecting all traffic 1n to 2f
this is only my option
but not my typeface - as per the´´ mixed typeface act 1935´´
vladan10
bigger dish that you can think .
pc card
Southern Europe,Crete
yes but if you have spectrum and make one check right now the only move you are going to see it is on 12427-12428 H.
have a look.
and small pick on 12497 H witch i have see it from the first day 11023 was up
TENERIFEFORUMTV
Persona non grata
1m
TENERIFE (Spain)
have a look.
14hours
887minutes
53229seconds
to early
vladan10
pc card
TENERIFE-TV said:
14hours
887minutes
53229seconds
to early
can you help me pls , what you mean?
it mean next 14 hour swap transponder from 1n to 2f
easydigital
Sweden
Stockholm
Something as definitely changed here in stockholm getting strong signals from Astra 2F /1N channel 4 much stronger!.......
C0re
Specialist contributor
Ede
VU+ Solo SE
Gelderland, The Netherlands
Channel 4 HD you mean?
easydigital
Sweden
Stockholm
I am receiving stronger signals "Astra 2F /1N " as somebody already said it could be because of weather conditions....
Whats thast supposed to show? Formatted like that its almost unreadable.
tothbros
Budapest, Hungary
im getting much stronger signals on all 1n tp's as well, but its because of the weather conditions. proper winter has arrived, signal always gets much stronger in these conditions
tothbros
Budapest, Hungary
so much so, that a fellow sathunter in hungary has managed to catch 11023H with an andrews 240 dish...even if only for a few hours in the late morning hours
trigger
Puerto del Carmen, Lanzarote
30W, 27.5W, 7W, 0.1W
4.8E, 9E, 13E, 19E, 23.5E, 26E, 28E
Technomate 5402HD super
Bein Sports on 25.5E
FTE Mini S2T HD Analyser
Horizon HD S2 sat meter
Lanzarote, Canary Islands
Signal levels might be up slightly as getting STV on working ok on my Sky box right now and would not normally see anything until late at night on my dish.
Just a side point 2D used to fade at night here but 1N gets stronger
Cheers
