Butchering audio cables
BadWithComputer
The Local Drunkard
30MB ADSL ONO, Spain
32" Internet connected TV
Many Satellite Dishes.
Humax HD Freesat Box
Spain
I want to connect my sky digibox to my speakers and music center, but i dont have to proper cables, i have 2 old Playstation 2 scart leads, (The ones with the male connections, the red, white and yellow. (Not the actual scart) If i cut off the male connecton, could i attach it to the other end of the wire easily? Like an f connector? See the picture for a better idea. I´d cut off the connector of 1 and stick it to the other end of the wire. Would it work?
The analogue audio levels used are fairly standard (roughly, "zero level"!). But, for a particular lead, it depends whether the audio connection is wired as "in" or "out" on the SCART connector!
If the SCART connector is moulded on, there's a 50% chance (just try and see)! Otherwise, you have to rewire it, which will be impossible if it's "moulded on".
Otherwise, SCART leads from "pound shops" can easily be taken to bits, and with a soldering iron there's no problem making a working lead (for SCART pins use/diagrams, do a google search).
