CCcam 2.1.3 is out
Oakey22
Penta 85cm, Quad LND, DM8000,Nabilosat Blackhole v11.
Staffordshire
nem2ace what HD issue?
dreamer786
i have a 7025 dreambox
england
Hi got it working with cccam 213 and smargo on debian server can we overclock the sky card now
B16MCC
Dreambox Gimp & Coder
2 Dreamboxes..........
--- DM 8000 HD PVR & DM 800 HD ---
Motek SG2100 & Triax 80cm Dual LNB
------ Fixed Dish 28e Quad LNB -------
---- Sly HD Full & 24" Apple iMAC ----
/var/tuxbox/config
dreamer786, with the card running ECM times around 0.1 seconds I don't think there's much to be had from overclocking it. I'll be moving my card to CCcam/Smargo tonight and see if it still performs as well as it does in NewCS/Omnikey. I doubt I'll bother to overclock.
dreamer786
england
Thanks for your reply i had mine in omnikey like u it was brilliant 0.1 in smargo it,d 0.2 seconds before cccam in smargo it was 0.3 still a improvement
shumifan50
2xDM7025(DVB-S tuner), DM600SPVR, DM800S, DM500S HD, Triax 90cm with MultiBracket 4 sats.
Europe
I now have the HD problem and movies not clearing using Smargo on Ubuntu.
On ubuntu the device is /dev/ttyUSB0 and entered the
boxkey: /dev/ttyUSB0 xx xx xx xx
but movies/HD not clearing - all other channels OK.
Does it require a pin as well? I was a bit wary about entering because of the warning in the cfg file.
B16MCC
/var/tuxbox/config
I'm at work yet mate and have not started work with this new release yet, but I'm pretty sure you don't need a pin in the config. That function is simply to auto enter the pin when its required.
Be aware of the difference in the boxkey arrangement between NewCS and CCcam.
NewCS = 12345678
CCcam = 12 34 56 78
andel
DM800, DM600, Technomate Diseqc Motor, 90cm Dish
Panasonic 42" Plasma 1080p
Pioneer VSX-LX70 Amp
Sky HD
B & W 5.1 Speaker Setup
Popcornhour Media center
Xbox 360
Watching T.V in the UK
I'm not sharing on a dedicated server just my dm800 and dont have hd entitlements on my shared card but the movies/sports cleared fine with just the boxkey entered like b16mcc has shown
shumifan50
Europe
I have the line exactly as shown in my post with a space between each digit but no joy. I also get a message "card intialisation failed" when it starts up but then it finds the caid and entitlements and it works, but only for the basic package not HD/movies. I did not try sport yet. I will test some more when the GF goes to bed LOL.
WildBit
-DM800 fixed on 28.2-quad
-DM7020 motorized
-Skystar HD2 motorized
-Cards&Cams&Cas
Ireland
Hi guys, finally got my whitey read in the smargo. Only works in cccam direct; with newcs I STILL cannot get it to read. No matter... omnikey reads @ 120 while with smargo 155 :eek:. I'll use the ominikey, it's a better quality reader :-worship. Good to know that the smargo is up and ready though.
Great to see n2 back in the emu, improvements all around.
Good stuff!
... and now we wait for the italians
Tomdigital
Linux Box
Earth
Hi there, when you did move to Ccam and Smargo, could you please post the config? Or maybe even add the Smargo option to your Config Creator?
Thanks a lot!
compufunk
DM 600-S, VU+ Duo,
Moteck SG2100, Fracarro Penta 85 dish, LG LH3000 42" TV + some computers
NW, Ireland
I've reverted back to CCcam/NewCS for the time being.
With CCcam 2.1.3 most ECMs were being delivered in 200 - 400 ms, but every minute or two an ECM would take around 900ms. Enough to cause a freeze. The server I was connecting to (which I control) was 1 hop away on a near by network (same ISP so not too much hoping over routers going on).
Setup was DM600 + Nabilosat DarkstarII and CCcam 2.1.3, with the card in the internal reader.
In my case, NewCS+CCcam seems to be a lot more consistent with ECM times averaging around 200ms.
Nick -D-vB
"SMARTCARD WRITE DELAY" seems to be broken for the phoenix on x86, the value is just ignored...
Anyone tested this with a real COM phoenix yet?
B16MCC
/var/tuxbox/config
======== STOP ========
Please don't turn this thread into another SLY UK 0963 thread. If you want to discuss using CCcam 2.1.3 with the white sly uk card then please use the extensive thread entitled Testing New White Sly UK Card CAID 0963.
Any 0963 specific posts in here will now be moved to the 0963 Thread.
Thankyou.​
compufunk
DM 600-S, VU+ Duo,
NW, Ireland
Please don't turn this thread into another SLY UK 0963 thread. If you want to discuss using CCcam 2.1.3 with the white sly uk card then please use the entensive thread entitled Testing New White Sly UK Card CAID 0963.
Thankyou.​
I realize you are trying to keep all the info together, but I dont see what the problem is here. The two things are related (CCcam 2.1.3 and the use of the 0963 card).
The reason I posted what I had found here was because it was specifically related to CCcam 2.1.3. By all means, copy it to the other thread if you like.
B16MCC
/var/tuxbox/config
I agree mate you post was quite relevant. The post I made was not intended for any one user, but a simple request to not fragment information. What you've not seen is the work done by myself and other mods / admins across the rest of the Dreambox section to stop many threads popping up about the same topic. The information in this thread will remain untouched but I don't want it to become another tangent thread all about the 0963 card.
Anonymous-A
I tried CCCam 2.1.3 with my TNTSAT card last night. It cleared the SD channels but not the HD channels. Am I missing a trick?
shumifan50
Europe
It seems you have to set the BOXKEY and the CLOCK FREQUENCY. I had left off the clock freq and had no access to HD channels, but this was sky so yours might be different.
sainbaba
p4, core2 duo, dm500s
sweden
SMARTCARD CLOCK FREQUENCY: ?
Smargo reader on ubuntu
Anonymous-A
Got my TNTSAT card working thanks to everyone here on the forum :)
How do you configure CCCam to specfically read the card slot first? I switch between my Irish white card using MGCamd in an Omnikey to TNTSAT sitting in the internal card reader, but CCCam looks at 'Network' before it looks for 'card', resulting in a delay before the TNTSAT channel decodes.
zoro25
Attack of the Clones
www.thetestmanager.com
Dreambox 800 - Nabilosat Image and 250gig Hard-drive (pointing at 28.2E)
Dreambox 7020 with 120 gig hard-drive disk - running a motorised dish
DM600 +DM500
although only usually the 800 and 7020 are both on.
I've got exactly the same thing, ECM times of 0.1 (on my Lan) and then every 10-15mins I get a freeze of about 10 seconds enough to be annoying.
I'll also be going back to a CCcam and NewCS double solution.
2.13 is good just not as polished as the latest NewCS
