Dish Adjustment Help
W
whizzwilly
Likes
Echostar AD3600 IP, 1m dish, 0.3 lnb, 36v Jaegar H-H mount, Dragon Cam 4, dynamite programmer, Dell Dimension 8400 3Mhz 160Gb
Rochdale
#1
Hi all
Hopefully someone can point me in right direction.
I have an Echostar AD3600i , .3Invacom LNB, 1m Eliptical dish and H-H motor.
At present I have the following satellite reception percentages
Astra 28E 85%
Astra 19E 90%
Hotbird 85%
Thor 1W 80%
When i get to 15W the signal is dropping to 50% and Hispasat 30W i am getting no signal at all ! I have been able to get 30W about 18 months ago but since i had some bad weather it is showing no signal.
As the others are all very high % i thought i must be "on" or very close to the "satellite arc" so why am i not picking up 30W (even as a low %).
Does this mean my elevation angle needs adjusting and if so which way (up or down). I manually adjust satellite positions E or W sometimes but in this case it doesnt work.
If anyone can shed some light on this i would really appreciate it.
Lancelot
Lancelot
Retired Mod
Likes
SS1.
36v H to H 62E - 61.5W
South central
#2
Looks like your dish may have moved on the O/P shaft
Is it a 36V motor or diseqc? and have you applied compensation/realignment after the bad weather?
L.:)
W
whizzwilly
Likes
Rochdale
#3
L.:)
Thanks for quick reply lancelot.
My motor is a 36v Jaegar.
What is the O/P shaft.
I haven't applied no compensation or realignment of dish only tried E or W manual search but no such luck.
There is no facility to adjust the skew although it's on the echostar menu ( whatever that means presumably up and down ?).
Given that i am getting excellent signal on East side but not on West indicates that i am not hitting the arc properly but any ideas on which way i should be moving my dish ie. am i hitting the arc too low or too high >
thanks
