Dragon cam/NDS problem
J
John T
Likes
60cm dish, dual LNB, Topfield TF5010PVR
North Staffordshire England
#1
I can hear the teeth sucking, and "Oh no told him so." as I type!:)
I have loaded a Dragon Cam (with the previous version software) into my Humax9100. All seems well, I can go into setup and input my Sky box number, but (with my Sky card in) it still is unable to decode channels. Any ideas as to what I may be doing wrong please?
M
Mickha
Likes
567
#2
Hi John T,
most of the time the problem is not getting the serial number correct, but you should still get the basic channels, from the Predator readme file:
Important: in order for the Sky UK NDS premium channels to work you
need to (apart form subscribing that is..):
-Tell your Dragon the serial number of the original Sky box your card is married to.
You can find this 10-digit number in the menu of your original Sky box,
services->system setup->system details.
You need the SERIAL NUMBER (and NOT the viewing card number!)
Now go to the menu of you Dragon, settings->NDS Box serial.
Here, enter the 10 digit serial number including any leading zeroes.
If your NDS card was already inserted into the Dragon, remove and
re-insert it after changing the Box Serial.
Now you're all set!
Failure to set the box serial will result in movie channels and other premium channels not opening.
The simplest faults are, having the card inserted incorrectly, should be chip facing upwards.
A patched receiver causing problems with the Dragon Cam.
If these are not the problems please post back
Best wishes
Mickha
J
John T
Likes
#3
Best wishes
Mickha
Thanks for your help Mickha, still not working. First I did have the card upside down, not realising that they go in the other way up to the Sly box, however it still does not work. I have tried every combination I can think of, including trying both slots of the CI.
I was supplied with the Dragon cam plus Prussian Galaxy5 card. The Dragon needed progamming, being ignorant I sent the Dragon off instead of the card, however that has been programmed with Predator 3.22.
So, I enter SYSTEM-STATUS-COMMON INTERFACE-SLOT1-SMART CARD on my Humax 9100.
( I have previously set the NDS Box serial number to the same as on my Sly box settings, which corresponds to the s/n on the box itself)
I then get:
Smart card unknown
1 ---
Not decoding
Your statement:
"A patched receiver causing problems with the Dragon Cam."
does not, I'm afraid, mean anything to me
any further help would be appreciated
M
Move
Likes
Humax CI-24 with Dragon Cam
combo box canal digital
CD Norway card
dish:90cm
LNB:0.3
1w(thor) /5e (sirius)
30 hispasat
comag sl 65(chess sl 35 patch)
thompson sky box
I then get:
Smart card unknown
1 ---
Not decoding
Your statement:
if you have 3.22 ,you dont have nds support.
only 3.21 at the moment....
Leee
Leee
Likes
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
#5
...they're hinting that NDS support is only out in the short-term ;)
J
John T
Likes
#6
Keep your mind on the subject John, keep your mind on the subject, not rhe avatar!;)
I did ask the chap who loaded my cam to put the version on that worked with NDS, I've emailed him to see if he can sort me out.
If not what other way is there to get regraded? Can I just send my card to someone to get it done? Also is it worth getting a programmer so that I can do any future updates myself? If so which one is recommended?
M
Move
Likes
CD Norway card
dish:90cm
LNB:0.3
30 hispasat
thompson sky box
i think you can have the 3.21 back...
also the card goes up side down in the cam.
i did test with sky italy and dragon is working .(official card)
T
tanman
Likes
big dish and seven receivers
fundee
#8
Hei guys and gals
looking at getting viasat card 1deg west for champions league football they said i need a 'NDS' approved cam is the dragon cam the one for me
thanx Tan
S
shadow28
Likes
Newbie
Malaysia
#9
Hi Micha,
I was wondering if you are kind enough to help out :-worship(or point us the right direction). Our provider in malaysia (Astro 91.5E) just changed from SECA2 to NDS. We have valid subscription card but was unable to view channels through my T-Rex Cam. Tried both the latest predator 368 & predasaur 226 files.
Here's some info on our provider.
_http://www.sat-television.com/showthread.php?t=50274
I was hoping to watch using valid subscription card through DVB-S (Twinhan) and T-rex CAM (for scheduled recording, etc) rather than through the original box. I have a Duolab CAS 3 programmer.
I hope you are kind enough to point me the right direction. Any help provided is highly appreciated, thank you.
EMPB
EMPB
Likes
Realise this is an old topic but not one person seems to have mentioned an important fact.
Sky White Cards dont work with Dragon CAM only the older Blue cards.....but the Predator file has to be patched with the correct CAIDs (Conditional Access IDentifier) 0961 for Sly UK Blue cards.
You can patch it with the DRA patcher or DragonCrypt or Pred Edit
