Dreambox Edit Help
hackenz
DM500s 1m Dish
Well I've just scanned all the transponders on 28.2 & the DM500 has put the channels all over the place. I've downloaded Dreamboxedit & installed it & transferred the necessary files to the PC.
I've attempted to edit the channel numbers in the left hand pane & saved them to the box, but on rebooting all is the same.
I'm pretty au fait with PC's but all this Dreambox stuff is new to me. Can anybody point me to a tutorial or give me a helping hand?
Thanks Guys
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
All I can do is direct you to here and advise you to have a read of the 2nd one down the idiots guide
stuboy
London
2.4m Precision Prime Focus Dish.
Dream 7020, V-Box II
Asus P5K E6570 (twin 2.66meg) CPU 8gig ram
Technisat Skystar2HD
DVBViewer, CoreAVC, VLC
Nebula DTT, 3.7.11
London
Newbie to this:- I have latest version of dreamboxedit 3.0 and a satcodx file .sdx i have just saved yet dreambox edit says " not a satcodx file" when i try to import, any ideas why? :confused
Regards
Stuboy
Miraculixxx
Dream7020 and T90
Germany
Regards
Stuboy
I have exactly the same problem and no idea why. Unfortunately I can't find any WebResource to get help :confused
Regards,
Joerg
daviddem
Hotbird, Arabsat and Nilesat. Currently using a cheap Mediastar box, looking into replacing it with a Dreambox
Dubai
Same here, and v2.02 is doing the same.
Also in the satcodx program, I am unable to save as anything else than a sdx file (all other options are greyed out).
