Echolink 777, need help
ral
Echolink EL-777 FTA
60cm Dish
Astra-19e/Hotbird-13e monobloc LNB
a few days ago I found lost the signal. It is suspected that the cable was shorted (cut when receiver was ON). How can I check receiver? What voltage should be in RF out sircuit (LNB supply)?
LNB supply either 13v or 18V (nominal).
ral
Echolink EL-777 FTA
60cm Dish
There is 19.4V. Is it good? Function "LNB power ON/OFF" works (voltage changes).
Couple hours ago tried to connect my receiver to my friend's dish - still no signal :(
satelliteman
That seems ok. You say the cable was cut, assume you've joined it? Might be worth checking over the join connection. Failing that, take a look at the dish :)
ral
Echolink EL-777 FTA
60cm Dish
It works! I installed new LNB (Astra19e/Hotbird13e monoblock from Maplin). But haven't got any channels from Astra, Hotbird only. Dish positioned for 13e. Do I have to change something in receiver?
For dish aligned to Hotbird:
Looking from LNB towards Dish
, right hand part of Monoblock in clamp.
In DiSEqC
Assign Hotbird = Port A (or 1/2 depending upon how your Receiver labels it)
Assign Astra = Port B (or 2/2)
You may need to rotate the LNB slightly clockwise (to raise the left hand/Astra portion of the LNB to simulate correct elevation) for best results.
ral
Echolink EL-777 FTA
60cm Dish
Thank you!
I've got two sats now.
The next step - Freesat Astra. Is it possible to use same dish (size 60)?
