davjen
- Jul 6, 2008
- Age
- 76
Echostar AD3000Ip Viaccess, Fibo 90cm Motorised Dish,
Invacom C120 LNB,
T/Rex.
- Devon
Hi there
I had a problem using my DVD recorder with the Echo. Each time I used the DVD , it turned on the Echo. Panasonic confirmed that the Pin 8 on the scart from DVD to be cut. The Echo was in standby and the scart from the Echo to the DVD was disconnected at the DVD side and I then very carefully cut The wire on Pin 8 but must have touched Pin 6, the result is audio, left channel no longer is working . Done checks on scart lead etc and tried using audio out phono connections - same problem. I now have PCB out to check. Already checked CE617 & R603 which look alright but I don't have a ESR meter. It is difficult to follow circuit. Is there anybody able to suggest what the problem could be? Everything else works fine. I would like a copy of the circuit diagram and parts list if possible.
Dave
Dave
