Nickolai
- Jan 1, 2000
- Berkshire
Peter,
once you obtained Echostar loader and the newest firmware version from the website you will need a null modem (9 pin female to female) cable to connect your receiver to a PC COM port.
There is a chance that the box will respond to an INIT command from the loader and will download the new firmware. If this happens - you are in luck, you will probably be able to operate the box again. Perform the factory reset then straight away.
Good luck
Good luck
