P
Peter_001
I've got a problem with my system. I've a Echostar 2500iD receiver/positoner. I hadn't used it for a while and when I tried recently I found that it is locked into a particular channel on hotbird. What that means is that when I turn on the machine...it goes to the previously selected satellite...which in this case is cinestar channel 14 on Hotbird. There does not appear to be any channel there. It does not say that the signal is scrambled or anything it seems to be searching for the channel. I cannot get the receiver to respond to any instructions via the remote to try and get the thing to move to another channel. If I turn it off...it simply goes again the the last channel used ie Cinestar and I can get no further with the damn thing!
Any ideas?
I do need some help here!
Thanks in anticipation.
Peter
Any ideas?
Peter
