few questions about motorised system.
D4ftpunk
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
StrongSat FTA Reciever
80cm Dish + 45cm Dish via Disecq A/B.
England
#1
Hi, at the moment i have a 64cm dish just pointed at hotbird and a 45cm pointed at astra2, i wish to remove the 45cm dish, and just use the 64cm dish, but i wish to pickup astra1/2 and hotbird and also some others if possible like sirius etc. Will 64cm be enough to pickup other satellites? i know for a fact it can pickup hotbird/astra1/2 perfect as i have re-aligned myself to test.
I am situated in the midlands in england if that helps.
Also what price should i pay for motor installation including parts
Likes
1,296
#2
You'll pick up quite a lot with the 64cm, but in my opinion a minimum for a motorised system would be 80cm. If you subscribe to Sky, then you'd be better off keeping the 45cm dedicated to that service.
D4ftpunk
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
#3
what kinda price am i looking at for parts+fitting ? and i heard dishes under 1m require cheaper less powerful disecq motor right ?
jimbo
jimbo
Retired Mod
Likes
Sky HD, TM6800HD, Manhattan Plaza ST550 and TM1500 CI+. 1.0m dish and 36v motor, Panasonic DVD HDD recorder and Panasonic video/DVD recorder. Sony G800 HD TV stand/surround system + Sony KDL40W2000. Infinity USB, Elvis, CAS1, CAS2.
Greater London
#4
Hardware + fitting costs will depend largely on where the dish is to be sited etc. If you are using a reputable company then they wil probably offer you a survey and price. Disecq will run a dish up to 1 metre quite comfortably.
D4ftpunk
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
#5
dish is wallmount on side of house
Likes
1,296
#6
Yes, the sub 1 metre dishes are not only cheaper but can use DiseqC motors, there are some prices mentioned in some of the other threads in this section, particularly with regard to DiseqC motors.
Can't really give you too much guide on fitting price, as the installation costs vary quite dramatically.
T
twag42
Likes
Amsterdam,Holland
#7
a triax 78cm dish would be a good investment for what you want to receive also the stab100 motor would be a good purchase.both of these shouldnt dent your wallet too much.
TWAG
T
twag42
Likes
Amsterdam,Holland
#8
if you wanted to really save some money..you could install both of these with a little help from the guys and girls on this forum/website or whatever it is :-) yourself.the reward for doing it yourself would be much better than paying someone to do it for you.
D4ftpunk
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
#9
is it easy enough to do though ?, since my neighbour has a motor and it looks very complicated :\. Also i dont really fancy drilling holes in my wall. I already have a bracket mounted obvoisly. Could it be used ?
gameboy
gameboy
Ding Dang Doo
Likes
5
Scotland
#10
Can you post a picture?
T
twag42
Likes
Amsterdam,Holland
#11
if youve already got the wall mount then thats a good start.add the motor then the dish and then you can start messing about with finding the different satellites.
D4ftpunk
D4ftpunk
Likes
Dreambox 7020
Dreambox DM500
Sky Thomsom Digibox
England
#12
im not so worried about aligning since i have done that before, im worried about drilling holes into my wall, if i already have the bracket fitted and sat dish on it is it just a case of taking off dish, and putting a motor in between the bracket and dish then re-align? i.e. no drilling heh
Likes
1,296
#13
Yes if the mast is straight.
