DishDick
- Apr 15, 2006
- Gran Canaria
Hi
Satelliteman I did say"Ok so there is little signal loss with fibre and you save a little on amps." but what I was saying is that you are using much more lenghts of fibre than with coax. With coax the max number of parallel cables between multi switches is 4, there is up to 7 with fibre, and its not cheap when bought pre-terminated.
Channel Hopper, all four outputs of the LNB are combined and sent down the fibre. The problem comes when you splt the signal. If you want one cable to run down the estate and you split into two the max signal you get is 50% out of each , so if you feed one fibre to coax converter from the first split it has 50% of signal, 50% goes to next output, but if you split again into 2, 25% of the original signal goes to the fibre to coax converter and 25% towards next converter ie (based on % of original LNB strenght)
100%
1st split 50% to Converter, 50% towards next house (which will have to be split again)
2nd split 25% to Converter, 25% towards next house
3rd Split 12.5% to Converter, 12.5% towards next house
4th split 6.35% to Converter, 6.25% towards next house
5th split 3.125% to Converter, 3.125% towards next house
6th split - signal too low.
Then the way I said
100%
First split 2 way 50% each
One feed left is left unsplit so 50% output, the other is split into 4, 12.5% to each, and each of those split into 4, 3.125% each. One 3.124% output feeds one converter, seven feeds totalling 96.875% go toward house two.
Second house, one feed 3.125% goes to converter six feeds totalling 93.75% go towards house three. you can see even at this point over 70% more signal is going to house three using this method than the single cable (but using six cables not one). These fibre to coax converters do not have a through put and have to fed directly from splitters. Look at the Global/Invacom PDF.
Thats the problem, If the signal converters had a throughput with minimal loss (due to built in amplification, yes we could have one fibre going from house to house.
100%
Then the way I said
100%
