blademedia
- Jul 29, 2016
- Sky
- UK
Great , another thing to try with the arm put the thick end in the vice don't tighten it too tight are you will squash the pipe, put a screw driver through the hole where the bolt should go, and start turning it keep applying wd40/whatever you have
