L
Having just discovered this fantastic site (quick bit of brown noseing) i just had to ask some of the questions about S*y Digital i've never been able to answer. They are as follows:
1. When they activate (or deactivate) your card are they actually sending an instruction to your card/box? (ie if you simply took your card out of the box wouldn't it mean that it would stay activated?)
2. Some time ago i notice that there was a programme stuck in my selected programme guide (you know the thing which gives you a warning when your programme is about to start). Simply, how can i delete it?
3. Living in Budapest (HUNGARY) i'm not able to receive ITV1. I've read a number of details about people experiencing the same problem and the first thing i did was check the footprint of the transponder. I've been told that it would be no use to buy a bigger dish. All i need is a definitive answer... can i or can't i receive ITV1 and if so what do i need to do?
Really sorry for the very long questions, but this is my first time.
Many, many thanks in advance!
Simon
Simon
