hd box?
P
pandashoe
Humax fox sat or Bush BFSAT01HD is there much difreance between them as there one hell of a pice diferance it's not for my main tv but one in my bedroom any reviews?
Tout Rond Bon Oeuf
P
pandashoe
have they sent out a fix for this problem yet?
Tout Rond Bon Oeuf
No.
They now say the box needs to be returned to the factory.
Complete horlicks.
P
pandashoe
thanks for your reply so have they went back to the earler softwear? & will this afect a new box?
Vipersan
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
The problem with updates sent 'over the air ' ota ...is that it requires a working box to receive it ..
If the box in question has had its tuner reconfigured or disabled by a previous -faulty or destructive - firmware ..
..or indeed ..if the stb has been rendered unusable and wont come out of standby ..
..then it cannot ever receive a new firmware upgrade or downgrade via conventional ota methods ..
This is why the owners are being told they will have to return the boxes ..in order that the receivers firmware flash can be accessed and re-programmed _directly_ by connecting to the main pcb ..
Some tv's and stbs ..were designed with this in mind ...and were equipped with a control or rs232 port to make this possible..in situe with a pc and the correct software.
Some boxes however ..did not have such a feature ...and the only point of access to re-program is a jtag header on the pcb.
rgds
VS
