nicedot
- Jul 19, 2008
- Age
- 51
- Technisat Multytenne, Vantage 7100 HD, Panasonic PZ600
- London
I am about to install a Technisat Multytenne 45cm dish which uses a fixed 4 LNB setup for 13, 19.2, 23.5 and 28.2 (i.e. all 4 LNBs are located in a fixed element and can't be adjusted individually).
My question is this: the dish has been designed for use in Germany with an average built-in LNB skew correction for that location. To get the best signal here in the UK (North London), do I have to mount the dish slightly rotated (i.e. with dish skew)?
And more specifically: using dishopinter.com, the dish skew is stated as 76.2 degrees for my location. Given the already built-in LNB skew correction for Germany (I assume the adjustment is 7.8 degrees as the average dish skew applicable for Germany at the same latitude to my location is 82.2 degrees), would I use an effective dish skew of approximately 84 degrees (i.e. theoretical dish skew of 76.2 degrees at my location adjusted by the assumed 7.8 degrees built in LNB skew correction)?
Lastly, are there any wall mounts where I can manually rotate the dish skew (the mount on the Multytenne only allows for the usual horizontal/vertical adjustments).
Many thanks for you help!
