help needed
b2.
bulk standard sky plus with multi room. laptop.
hampshire
i asked this q a couple of days ago. freind bought a silvercrest 57cm dish and decoder from lidl's. got all english channels but no german ones. need german channels. on the set top installation menu. tp scan i have got the 19.2e sattelite up with 80% strength and 60% quality. all german channels say no signal!!! desperatly need help
Did you move the dish as per our replies in this thread?
b2.
hampshire
Yes mate the only signal i picked up was the original one. all the other signals on the tp scan were reading 36 str 11 qua. definatly pointing the right way according to the decocer. the only 2 sats picking up sig were 28.2e and 19.2e could it be equipment problems.
Are you still receiving any English channels, if not, what channels can you actually see?
b2.
hampshire
the only place i can actually receive channnels is the original p[lace the dish started. as with the previous message moved dish 9 degrees higher and west nothing. do you know this set top. is there a setting i'm missing. back to previous message tp scan on 19.2e says 80% sig str, 60% qua. how far west are we talking. your help is most appreciated.........have you ever heard a german argument, not nice!
If the dish is back where it was with the English channels, then it will not pick up the German channels. Dishes need to be setup to within a degree of the satellite, you need to move them slowly whilst monitoring the signal strength and quality on the receiver.
b2.
hampshire
sorry blue dont mean to sound like an ametuer. tried to move dish in small incriments from 9 degrees higher than original setting. got nothing. is that 9 degrees on the sat dish arm measurement its self. probably total muppet. this is all new.
It is 9 degrees to the West and a little higher, only a couple of degrees.
b2.
hampshire
got it completly wrong.gone 9 degrees higher. still doesnt quite explain why on decoder it says alls ok. on the decoder it asks for paticular sat. put it on 19.2e like said sig levels are fine. doesnt mke sense
Forget the signal level, it is very inaccurate on many receivers, just go by quality.
b2.
hampshire
will do. thanks, try again.
2cvbloke
Bulbs need shelter too...
Near Pontop Pike, Co. Durham
I guess it's a Silvercrest SL-65...
As rolfw says, ignore the signal meter on this box as it'll say it has a signal even when it doesn't!!! I use a cheap in-line signal meter with my SL-65 as that's more effective than the box's own meters... :)
