Help required
H
Happydude
Likes
std
#1
Hi, I would appreciate it if I could get some help for a set up I am trying to achieve - panamsat 10 on c band which I think is 68.5 east.
What is the best way of going about this, where can I get the equipment and the services to achieve this set up.
Likes
1,291
#2
Will depend a lot on where you are, the more information you give, the better the answer.
H
Happydude
Likes
std
#3
Thanks for the reply. Well basically, I'm in the south west and I want to pick up the channel tellytrack, which I'm told you can recieve with the set up in my original post. How do I go about this?
Likes
1,291
#4
Can't see any setup in your first post, but the biggest problem for you is going to be line of sight, as that sat is very low on the horizon. We have a couple of C Band experts on the forum who will be able to advise on minimum dish requirements.
Likes
8,550
Skybox F3
Its videoguard encoded - unless you have the access to the correct subs cards you can forget it.
In any case its going to be virtually on the horizon, so unless you have a perfect view out to the south east, you arent going to see it anyway.
H
Happy-Buddah
My old employer has a couple of 6m dishes trained on that sat. Line of sight clear out to sea.
H-B
H
Happydude
Likes
std
#7
How can you get hold of the correct subs cards? Can they be purchased?
At the moment I just have normal sky dish, however I am prepared to pay for the extra equipment that will be required. I live in a mid terrace victorian house so may struggle to get a clear view, but I could get the signal where my brother lives.
Likes
8,550
Skybox F3
A SKy dish will be waaaay to small :D Hope you got a big garden as the power levels across the UK for the C-Band transmissions (34d:cool: suggest something BIGGER than 3m in diameter!!
I rather suspect subs cards will only be available to betting shops etc.
H
Happydude
Likes
std
#9
I was told from someone who claims to have tellytrack that you don't need a decoder or a card as with c band it's free to air.
Likes
8,550
Skybox F3
We can only go on what the frequency websites tell us & they say its Videoguard.
h**p://www.lyngsat.com/pas68.html
4099V
Not that its going to make any difference to you unless you want a 10-15 foot dish in your garden:D
H
Happy-Buddah
Don't you just love it when people come onto the Forum asking for information and then do not believe you when you post an answer.
4099 V
tp 21
Telly Track
Videoguard 1 512 650 E
H-B
Likes
3,436
You can receive it on the Europe*Star satellite at 45E, ku band 11495V. I used to watch it before it went encrypted.
H
Happy-Buddah
You beat me to it Llew. I think that the transmission on the South African beam is fta though.
Cheers H-B (J)
Likes
3,436
A little way over the horizon, that one HB :)
H
Happydude
Likes
std
#16
Cheers H-B (J)
I was told you can watch tellytrack via two beams, one which is encrypted which has been mentioned - 45E, ku band 11495V. But I'm told you can pick up free to view signal via panamsat 10 on c band which I think is 68.5E. Do you really need a 10 foot dish? Can this dish go on the roof/chimney?
Thanks for any help
Topper
Topper
Amo Amas Amant Admin
Likes
3,341
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#17
Thanks for any help
Don't think you would get planning permission for that Happydude and if you did the first time it got a bit windy your chimney stack would probably fall off !
:D
Likes
1,291
#18
Should be OK Topper :)
Likes
8,550
Skybox F3
OK
<exasperated>
You need a 10 foot dish MINIMUM for C-band because of the low signal power levels.
Its encrypted in a secure system.
If you want the fta transmission move to South Africa.
End of story.
Thread closed.
</exasperated!>
