- Oct 21, 2006
- See signature
- North Somerset
Hah... Well, no hurry. I ordered that 300 piece set Martin linked to, so will be nice and new. The other is a bit mangled now with me trying to remove it.
For now, I used the middle wire from a coax cable to keep it in place and put the gearbox back together.
One thing I noticed is a bit of play between the two sprockets, which I can only assume is normal? It makes the magnetic wheel move maybe 1/8th of the way in either direction without the motor moving. Once the worm drive is engaged with the main rod, there won't be any play in it but during directional changes, it is likely to count one or two pulse without the main gear being engaged and causing miscounts. I noticed it with the 1.5m Gibby but doubt I will with the 1m. Not a huge deal but annoying and I am guessing replacement sprockets aren't available.
Thanks for all the help so far chaps!
