JSC Sports +5 / +6 / +7 / +8 13E
pipino
Back from the dead
2X Channel Master 1.20 , 1X Channel Master1.80 ,1X Channel Master 2.40, Motorized Gibertini OP150 , Motorized Fibo MF90 ,, 70cm eliptical raven ..hirschmann fibre glass 1.20m
Comunidad Valenciana..ESPAÑA
Analoguesat said:
Im amazed - none of the other new channels threads have anything like 50 replies on them with 3000+ views!
its quite normal so much interest , Al jazeera sport become very hot package here in europe simply for its valut and all 8 channels are packed with all sort of football ..shame they are making a big mess with this activation stories
@LAURO
i know someone who works with aljazeera technical staff (not directly with aljazeera sport ) he is trying to help as much as he can ,he gave me some infos about whats going on in their mess
pipino
Back from the dead
LAURO2008 said:
what do they have in mind for fixing the problem?
thanks
all depens of the french guys from viaccess ,apart of puting a call center sending activations i think they dont have a clue whats going on
LAURO2008
* Clarke Tech 5000 HD Combo Plus * Gibertini 104 cm * Invacom TNH-031 0.3dB * Diablo 2 + CAS 3 plus * motor GT SAT - DM15AT * 53°E - 58°W in USALS * Full HD LG Scarlet 42lg7000 * Western Digital HD TV Player Live *
NL+IT
Hi pipino,
yday night nothing happend with unblocking the card due to the 30/09 ...if also tonight will be the same then I can send it back to the UK e-shop where I bought it and see if they can replace it.But I'm not sure yet ...shall I wait for news from your side? can't I send it to your aljazeera technical guy?
thanks
pipino
Back from the dead
LAURO2008 said:
Hi pipino,
thanks
no need to send the card anywhere ,the best thing is send an email with this title "Full reactivation needed" , to callcentre @ aljazeerasport.net and put the serial number(s) explaining that you been trying to refresh the signal many times with no success,please have some patience to have a reply but mean while leave the card on a correct decoder on JSC+5 ,i´v just reactivated 8 cards on 1 go having exactly the same problem like yours
LAURO2008
NL+IT
my goody....I can't believe it...that it so easy!
If it works, how can I thank you?
Edit I got the following message:
Delivery has failed to these recipients or distribution callcentre @ aljazeerasport.net
Is it the right e-mail address?
I also tried callcenter @ aljazeera.net with the same result
pipino
Back from the dead
I also tried callcenter@aljazeera.net with the same result
look here ----> _http://www.aljazeerasport.net/contactus/
and if you have failures check your internet provider..may be it has some blocking to arabia ,in that case use a proxy from the middle east ;) ..good luck..
cheers
LAURO2008
NL+IT
cheers
I changed proxy but nothing...you got a PM:)
BTW, thanks for the recommendation Pepino. I got a card (Viaccess 3.0) from Dream or Demon, whatever it's called. 85€ + IVA. I think it's gone up to 90€ now. I put it in the Manhattan and it took about 5 minutes to activate. Now it says: From 16.09.2009 to 16.09.2010. All 8 channels work. I don't have an HD receiver but that is supposed to work too.
LAURO2008
NL+IT
cheers
Just to let you know that the card was sent back to the e-shop in UK and after having worked very close to Aljazeera technicians in order to reset the card, the shop sent me a brand new one with 8 channels and valid 1 year as of this week ...:toke:....Gentlemen !!!
DaDiDo12
DM800
Algeria
Thank you Pipino , your post was very usefull for me , im from Algeria , and i have 3 Viaccess card that didn't work ,they got renewed since 10 days ,but still didn't start , i contacted a JSC agent but he said i have to change the CLASS to 25 ,i have an Aston Simba sattelite receiver ,and i don't even know if it's possible to change the CLASS .
i sent them today an email about Full activation , so please tell me if you got a resolve to this problem .
I am waiting you .
pipino
Back from the dead
I am waiting you .
hi Dadido
first welcome on Board,
if you have Simba with 2slots i beleive its model 202 then it should work with your card providing its viaccess of course,the best way is to call them personaly in qatar and ask for the technical departement then expalin your problem ask for this name i´m sure you will guess it W***D ;) ...cheers
DaDiDo12
DM800
Algeria
First thank you for fast answering me .
yes i have a Simba 202 and a Dreambox Dm800 , but i prefer the Simba for card .
i already called them , and they just asked me to put the card in the receiver and wait in +5 .
do you think i should ask them to do a full reactivating to my card .
and the problem is that i ignor why with CLASS 25 the card didn't work ,should i ask them to modify it to 225 ?
pipino
Back from the dead
just ask for W***D and tell him to fully reactivate the card..thats it
DaDiDo12
DM800
Algeria
ok ill do it tomorrow and post the result here .
DaDiDo12
DM800
Algeria
i called them , and they asked me to put the cards in a STREAM receiver .
