LNB/Echostar problems
R
RENF4D
I have a mono block lnb that switches between Hotbird and Astra. Since I did the OTA download for my 3000ip and then restored to the 900 version, I cannot get all the channels. It just says 'No Channel'.
I have the setting for the universal but don't get all the channels. I also use Disecq to switch between satellites.
Are there specific settings to use or do I need to change the lnb or receiver.
Many thanks :(
You need to setup the diseqC commands in the satellites/LNB menu to either A, or B, depending on which is which.
If you are pointing at Hotbird and Astra 1, try A for Hotbird and B for Astra, then if that doesn't produce results, try the other way around. :)
R
RENF4D
Tried, but I only get about 20-50 channels on Astra & Hotbird. Nothing over frequency 11900.
Is there a setting for the lnb, or receiver, or at worst do i change the lnb.
Thanks :confused
