hairybadger
Bricoleur
- see sig
- near Geneva, Haute-Savoie, France
OK, am looking at that and thinking "if I had something like that where on Earth could I put it so my wife wouldn't see it?"...
I took that photo in South Africa. Would be difficult to ship the beast back to Europe, plus I don't think my garden is big enough....I´m thinking, behind your Avitar!
Odd really, as it's not really very hairy or a badger. ;)I took that photo in South Africa. Would be difficult to ship the beast back to Europe, plus I don't think my garden is big enough....![]()
I needed a picture of an animal, and that was the closest thing that I could find that was taken by meOdd really, as it's not really very hairy or a badger. ;)
Show a close up of the existing bar. Figure we can get a length of same thread bar for only a few €'s and make one up. If needed can get my friend Dave to custom make, won't cost me that much!Stunned !! re the Marrafa 1.8m dish.
Looking for 57.0ºE found that the threaded bar... declination/inclination was not long enough !!!
Had to use a tie to secure the declination. View attachment 75570 View attachment 75571 View attachment 75572 View attachment 75573
Cost not important but would like to have made a threaded bolt for the Marrafa 1.8m that at present is of 50cm of length so some +/-70cm is needed.
Some have said that as there is not many more sats because of line of sight no point in spending that money.....that is not me so is it possible to have made as a one off to make this arm......obviously in inox.
Hard work manually especially as the temp here reached some 30.9ºC !!
I know that many here have the capabilities or contacts to produce such a thing.
¿Are we talking for a one off of some €100 to €200 or...?
Thanks for that.....would be great to get this made.
Great reply and that is appreciated Brian thanks.........quite happy to remove the bolt and nuts and to give to you/friend dave to use as model.Show a close up of the existing bar. Figure we can get a length of same thread bar for only a few €'s and make one up. If needed can get my friend Dave to custom make, won't cost me that much!
Message me your details and I will do as you need....will pay upfront as you wish.
Really pleased with your help. This is what this place is about.![]()
Not a specialist in the spec field Brian so quite happy to just give you the whole existing arm in question for you to replicate to a length of some 70cm in length....quite happy to pay in advance....just so pleased that you can help and being somewhat local is a bonus.....great, thank you.Photo and nut size, ie 19mm or 22mm etc should allow me to calculate actual thread size. That said, it would appear you have a few tools and know how to use them. Got a calliper? That will tell us the thread size. ( Any other member who knows the spec please feel free to chip in ) Only potential problem is the end that attaches to the face mount ring. Cannot see too clearly, but figure a nut of the correct size welded on the end would do this job!
Not a specialist in the spec field Brian so quite happy to just give you the whole existing arm in question for you to replicate to a length of some 70cm in length....quite happy to pay in advance....just so pleased that you can help and being somewhat local is a bonus.....great, thank you.![]()
You could just joint it LP and save messing around, all you would need to do is buy a threaded rod connecter and a small piece of treaded rod.
http://www.directchannel.co/threaded-rod-support/threaded-rod-connectors
Wow...different world when you are ignorant of the pros...... sure I will arrive with what I want....thanks to you all.Its even a easier fix at the other end Brian, two bits of steal with two holes 1 extra bolt job done
Yep, that may work, but getting the connector through the adjustment nuts could prove difficult, esp if it at the point of elevation, unless you could invert the rod so the connector was only 20-30 cm from the face mount ring, but still the problem of connecting to the ring:mad:
