Lucky again....1.9m(1.8m)....secured.
hairybadger
Bricoleur
46.1N 6.4E
see sig
OK, am looking at that and thinking "if I had something like that where on Earth could I put it so my wife wouldn't see it?"...
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
1.2m dish + Stab HH120
TBS 5925 USB
Octagon SF8008 4k Twin
GTMedia V8 UHD
GTMedia GTcombos x 2
Goldmaster SR525 HD
Sat-illimitè F300 hyper
62.0ºE - 63.0ºW
Alicante, España
Installed dish stand today....maybe an overkill with 8 threaded bolts but wow do we have some extreme winds here.
Feel so lucky....2 x 1.8 dishes for some only €310 + installation bits !!
Have Granddaughter the weekend but hopefully dish face will be fitted soon.
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
I've seen much worse "professional" installs than this!
Looks good!
Retired Mod
www.timo.me.uk
I took that photo in South Africa. Would be difficult to ship the beast back to Europe, plus I don't think my garden is big enough.... :)
Odd really, as it's not really very hairy or a badger. ;)
hairybadger
Bricoleur
46.1N 6.4E
see sig
I needed a picture of an animal, and that was the closest thing that I could find that was taken by me :)
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Stunned !! re the Marrafa 1.8m dish.
Looking for 57.0ºE found that the threaded bar... declination/inclination was not long enough !!!
Had to use a tie to secure the declination. respect-048.gif Copy of P1000532.jpg Copy of P1000534.jpg Copy of P1000535.jpg
Cost not important but would like to have made a threaded bolt for the Marrafa 1.8m that at present is of 50cm of length so some +/-70cm is needed.
Some have said that as there is not many more sats because of line of sight no point in spending that money.....that is not me so is it possible to have made as a one off to make this arm......obviously in inox.
Hard work manually especially as the temp here reached some 30.9ºC !!
I know that many here have the capabilities or contacts to produce such a thing.
¿Are we talking for a one off of some €100 to €200 or...?
Thanks for that.....would be great to get this made.
Archive4
Had to use a tie to secure the declination. View attachment 75570 View attachment 75571 View attachment 75572 View attachment 75573
Show a close up of the existing bar. Figure we can get a length of same thread bar for only a few €'s and make one up. If needed can get my friend Dave to custom make, won't cost me that much!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Great reply and that is appreciated Brian thanks.........quite happy to remove the bolt and nuts and to give to you/friend dave to use as model.
Message me your details and I will do as you need....will pay upfront as you wish.
Really pleased with your help. This is what this place is about. :-applause
Archive4
Photo and nut size, ie 19mm or 22mm etc should allow me to calculate actual thread size. That said, it would appear you have a few tools and know how to use them. Got a calliper? That will tell us the thread size. ( Any other member who knows the spec please feel free to chip in ) Only potential problem is the end that attaches to the face mount ring. Cannot see too clearly, but figure a nut of the correct size welded on the end would do this job!
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Not a specialist in the spec field Brian so quite happy to just give you the whole existing arm in question for you to replicate to a length of some 70cm in length....quite happy to pay in advance....just so pleased that you can help and being somewhat local is a bonus.....great, thank you.:)
Archive4
PM me your address and phone no. We will go from there!
Archived-1
Persona non grata
uk
Archive4
You could just joint it LP and save messing around, all you would need to do is buy a threaded rod connecter and a small piece of treaded rod.
http://www.directchannel.co/threaded-rod-support/threaded-rod-connectors
Yep, that may work, but getting the connector through the adjustment nuts could prove difficult, esp if it at the point of elevation, unless you could invert the rod so the connector was only 20-30 cm from the face mount ring, but still the problem of connecting to the ring:mad:
Archived-1
Persona non grata
uk
Its even a easier fix at the other end Brian, two bits of steal with two holes 1 extra bolt job done
lovelyperson
Dreamer
Alicante, España
2.0m PF dish
1.8m PF Famaval
1.8m PF Marrafa
1.4m Tecatel offset
TBS 5925 USB
GTMedia V8 UHD
Goldmaster SR525 HD
62.0ºE - 63.0ºW
Alicante, España
Wow...different world when you are ignorant of the pros...... sure I will arrive with what I want....thanks to you all. :)
Archived-1
Persona non grata
uk
You would just cut back the old threaded rod to a position it would not be in the way, and order a new longer bit, like this.
Archived-1
Persona non grata
uk
Just to add, if you do decide to do it like that order 2 locking nuts LP.
