Monoblock Lnb Help! FOR ECHOSTAR 2110- 2CI VIAACCESS
M
MR WORRY
Likes
HI
I bought a dual [2] LNB with disceq facility.
I can get the Astra 19.2 satellite. The settings show
LNB TYPE: TYPE 1
LNB FREQ: UNIVERSAL
LNB FREQ: UNIVERSAL
DISCEQC: MINI DESC
DISCEQC PORT: 1
This works fine for Astra and I get a really strong signal level and
quality [90%].
I then tried to set up Hotbird by doing the following
1 - program satellites
1 - satellite - selecting Hotbird
these are the setting that show up
Satellite: 013.0E HOTBIRD
LNB TYPE: TYPE 2
TP/POLAR: 12520/V
etc..
The signal strength is 10% level
and 10% quality.
What is the problem?
Why can't I get Hotbird?
What side is in the clamp ASTRA OR HOTBIRD?
My dish is like his
[O] THIS LNB SIDE IS IN THE CLAMP
THE CABLE RUNS IN THE MIDDLE OF LNB
O THIS LNB SIDE IS NOT IN THE CLAMP
Likes
1,291
#2
On most DiseqC LNBs port number one is the western LNB, so should be lined up on 13E, then port 2 or B should be set up for Astra 19.2.
Both LNBs should be set as Universal, Low band LO 9750 High band LO 10600.
M
MR WORRY
Likes
Many thanks for you reply,
since I am a newbie, does that mean the side in the clamp is ASTRA 19.2?
If the below diagram is my satellite
(0) is this Astra in the clamp?
O is this Hotbird?
could it mean that I need swop the clamp side to thisa way round?
O
(0)
M
MR WORRY
Likes
I actually solved the monoblock problem for my receiver.
I used a sat finder device to set the dish, and discovered that the lnb in the clamp was hotbird (a) and the other was Astra (:cool:. As I am using a disqec 2.0, I had to set the option to mini disqec on the Echostar 2110 2CI Viaccess receiver.
That solved the problem.
Got brill reception on both hotbird and astra!
Likes
1,291
#5
Thanks for the update, sorry I missed your previous post, was a bit tied up yesterday. :)
Glad you got it sorted.
