Moteck SG2100 step motor
whatsthis
Likes
DM7020 Screambox
MAC OSX & windowzz 98SE
Gemini
1664 on tap
13°E
#1
Hi
Does anyone know how far the dish moves when I step it manually east or west on a Moteck SG2100 motor.
I am trying to find a weak satellite by manually stepping around from a strong one.
Thanks all
mhku
Likes
20
TM Nano ~ sg2100
Midlands
#2
less than 1 degree. I used the "Move" command (Dreambox) on every satellite when storing the position to find the strongest signal.
kalamar
Likes
Some (most) have menu settings for number of steps motor takes,see the menu in whatever (reciever/card) you are using for this.
Likvid
Likes
5
Stockholm, Sweden
#4
Its 0.1 degree west or east.
USALS is the best thing you can use today.
whatsthis said:
Hi
Thanks all
T_G
The Consumate Dreamer
Likes
212
1 GigaBlue Quad plus, 1 Dreambox 5620, MOTECK SG2100A DISEqC Motor, 120 cm noname offset dish, Humax 95 cm offset dish and a few UK digiboxes.
Somewhere where the Sauer is Kraut and the Wurst is Brat
#5
What you could do is set the motor on 1 west for instance, and then move it manually with single steps to say 5 east, whilst counting the steps. This will give you an idea how much you need for moving the dish.
steffan_st
A bit enthusiastic
Likes
Gibertini OP 125 L, Smart Titanium lnb with CD-80 feedhorn, Moteck SG-2500, Azbox HD Premium+, some 5 meters of good quality coax
Sweden
#6
That's a good idea mate!:)
T_G
Likes
212
#7
Lol I had some issues with my Dreambox and motor, made me get inventive trying to find the sats.
