Help Required Motor setup
cwsat
Gibertini 85cm / Dragonsat 3000 motor / Inverto Black Ultra LNB
Midlands
Update - I have Thor and the majority of the eastern sats. The western sats are blocked by an obstacle.
USALS is massively overshooting every Sat for some reason.
My longitude is -2.4W.
I can’t work out how to put a minus into my receiver.
It’ll take 111.1 but not 357.6.
If its doing consisently to one side OR the other, then the motor needs to shifted very slightly around the pole to take that into account of that.
OTOH, if it's overshooting East when you drive the motor East and West when you drive it West, then that's a clear sign of backlash in the gearbox (both my Dark Motors suffered that to begin with), and needs to be adjusted out.
Mickha
North West
Yeah that’s what I had it set to when it was overshooting the sats.
Either it's a problem with your receiver, motor, or you haven't set it up correctly.
When you say massively over shooting, by about how many degrees?
When your dish is aligned to 1W, the 0, on your motor should be pointing to 2.4W, so as you stand behind the dish, 1.4-1.6 degrees to your right, West.
cwsat
Midlands
I have had to move the dish to a more wind shielded place. I moved the dish round to 0.8W on USALS and then moved it.
Turned the receiver off, did a full USALS reset and realigned the dish with the motor at 0.8W.
It’s now working perfectly.
My scaffold pole is bobbing around a bit too much for my liking so I think I’ll concrete it at some point.
cwsat
Midlands
Any recommendations for fringe EU satellites to test the signal strength and quality?
Seems that you sorted out the previous misalignment of the motor on the pole when you moved the latter.
Had to concrete the scaffolding poles for both the Gibby and the TD110 - and then add steel stabilisers to the adjacent fence to ABOVE the DMs to pull the poles upright because they were bending under the weights!
Regardless of that problem, you'll need to stabilise the pole so it doesn't "bob around" or the dish will never point consistently at any satellite (especially those with weak signals)!
"It all depends" on what your visible arc turns out to be (no point in us suggesting sats that the dish can't actually "see"!)
Mickha
North West
Check out lyngsat, how far west can you get? You can try 3W and 5W.
For east you've got a number of satellites, you can check.
Have a look at william-1's strongest transponders, peak your signal quality, then try a blind scan.
cwsat
Midlands
42e to 7w before obstacles, walls etc get in the way.
Regarding the pole, is concreting it the best way to stiffen it up?
Satspot
Technomate TM5402 M4
1.2m Triax dish
Technomate H to H motor
Ireland
As you’ve a reduced visible east/west arc to play with you should be able to push your dish further east. Maybe reposition your installation to concentrate on the easterly portion of the arc. Maybe include a picture of your current installation so suggestions could be given. Some interesting Ku stuff in the 50s E to be had. Really depends what you’re after.
cwsat
Midlands
I have a tree just past 42e. If I bring the dish further forward I’d get the full eastern arc but then lose 0.8W.
Nowadays, there doesn't seem much unencrypted stuff on 0.8W except Chinese "semi-propaganda" and various religious channels - but a lot more unencrypted stuff further East than 42E (& especially on 52E).
OTOH, with a DiSEqC switch and an extra 1m fixed dish "tucked discretely away somewhere" you could also get 42E/46E/52E fairly easily and keep 0.8W.
Photos would help?
cwsat
Midlands
Photos would help?
I am not that fussed about 0.8W to be honest.
Is there much past 4w apart from Hispasat?
Manikm909
Small'ish Dish Man
Kent, UK
no unless you went bigger for C-Band stuff.
cwsat
Midlands
Photos would help?
Beyond 42e will I get much on my 85cm Gibertini?
You'd get some of the stronger channels on 8W (but not most of them) & reuters news on 22W if you could get that far.
Definitely get quite a few on 52E 53E (oops!)and maybe some on 46E
mike1
Non-28.2° Sat Specialist
Yorkshire Television
Triax 64cm triax ( Darkmotor ) Inverto Black Ultra.
T55 - 28E/19E/13E/1.9E
Mutant AX 51 Open PLi
GT Media V7SX
Hi
This is a example of my USALS setting in Hull on technomate. Can you provide a screenshot?
edit- seems you may of sorted it now!
cwsat
Midlands
Hi
All sorted now :Y
I had my old motorised system for over a decade and used to religiously run Diseqc because USALS was always inaccurate.
Turns out the dish was setup wrong all along!
All sorted now :Y
Great!
Maybe a quick summary of what was wrong might help others with similar problems?
