I flashed it with "3018SE_TSR_na_TSR_15[1].1.buc" and it is stucked on a flashing 8.8.8.8., it won't take any re-flashing and always shows "Download fail". I do not know what to do. Please help me to solve this problem. Thanks in advance!
nr66 said:Hi she12126,
it looks like it's a bad upgrade and the only way to restore ur receiver is by erasing and reprogramming the flash memory.it's a little bit tricky but manageble if u don't mind a bit of DIY(Do It Yourself).
-first, u need to make a JTAG cable, JKEYS softawre and bin.file for ur receiver's
flash memory.
-lunch JKEYS to flash programming(erase full then reprogram) if successful then,
-start ARIONER to download the right boot this time and then the latest firmware.
more details about the procedure in www.ucascity.com presented by yesyes85.
good luck,
regerds,
nr66
flash memory.
good luck,
regerds,
nr66
