NDS firmware for SAGEM ISD 4150
Likes
GERMANY
#1
I'm looking for NDS firmware for Sagem from Viasat. Is there any way to download actual soft from Sirius with force download?? How to do it (any keys combination?)?? Or is there any p012.zip with latest NDS soft for that Viasat receiver available on the net? I haven't got updated my receiver in 3 years :/
Best Regards,
TOM
Topper
Amo Amas Amant Admin
Likes
3,322
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#2
Welcome to the forum theking7
Well either I am confused or you are! If you want an upgrade for your sagem receiver it will have nothing to do with NDS software. NDS software is contained in the cam either CI type or on board but still has nothing to do with receiver firmware. If you had searched the forum you would have found this thread but there has been no update to the thread in 3 years. NDS software is not freely available anywhere as encryption software floating around will only lead to it being compromised.
Likes
GERMANY
#3
I've missed a soft upgrade from Viaccess to NDS on Viasat receivers in 2004, which was done through the satellite.
I thought that the latest software should be available on Sirius2 4,8E?!
Topper
Likes
3,322
#4
Being three years since I very much doubt it and if it was only available OTA then I am sure it will have been withdrawn by now. 3 months is a long time in the world of satellite TV:-Nooo
Likes
GERMANY
#5
I found data stream with the latest Sagem soft on Sirius. It's channel with ID "01 39 01 33" @ 11996H 27500 3/4. How to grab the data using SkyStar2? I tried DataPID Scanner + Prog file grabber and Data PID scanner found pids, which are carrying web services (HTML, JPG, GIF). Is there any option to download a software from channel that the only PMT PIDs or SIDs are known (i don't want all that are founded by data pid scanner?)? I want download only from channel with ID: "01 39 01 33"
