newbie needs help entering keys.
blackninja
I've got a smart centurio ci with an irdeto freecam (viaccess and seca also seem available on this cam according to the menu). I've found a few keys on the net and can open the enter new keys screen but I don't know how to type in letters or spaces using my remote. How do I do this?
Cheers for any help.
From memory you can only enter irdeto keys into a freecam, you enter them in decimal format, you can use a hex to decimal convertor for this.
blackninja
Sorry to sound thick, but what's a hex to decimal convertor?
Just the bit in red.
blackninja
Thanks rolfw.
The keys on that site don't seem to work. Think they expired. Do you know of any up to date irdeto sites?
I worked out how to convert from hex to decimal and I converted some current viaccess keys (from la-cafetera.com) into freecam keys using this technique. I flashed my freecam to viaccess. However these keys don't work either. Why is this?
