No Picture!!! HELP
M
MattieC
Likes
Location germany, Sky full package, 80cm dish, pace box
#1
I live in Germany and ive had Sky digital for 3 years now with no problems. However, this morning before i left for work we had some heavy rain and winds and the picture kept freezing. Nothing new here as this always happens when bad weather. However I went home at lunchtime and i had no signal so i realigned the dish with good quality and strength showing on screen setup but still no picture or sound?
Im puzzled - anyone any ideas what to do?
Cheers
Matt
Likes
1,291
#2
Try switching off at mains and re-booting, very often cures this type of problem.
M
MattieC
Likes
#3
Hi - i tried that already and still the same :-(
Likes
1,291
#4
Is it sucessfully scanning fo channels?
M
MattieC
Likes
#5
Hi, I get all the listings for the "entertainment" section but when i switch to say Movies or Sports then it says searching for listings and not a lot of action?
Regards
Likes
1,291
#6
There have been problems with some of the early Pace digiboxes, the 2600 is a particular sufferer, you may even find that a forced software update will cure the problem. Can you view any of the channels in the entertainment section?
M
MattieC
Likes
#7
Hi Rolf, i appreciate your help.
No i cannot view any channels at all even the ones that are listed.
You know when you said reboot did you mean unplug at the mains beacuse i only switched off the box, also, i never remove the viewing card but when i did today it semmed very "scorched" where the chip is. Is this normal?
I really cant do without Sky here in Germany :-(
Best Regards
Likes
1,291
#8
To reboot, you need to unplug the box. It is not normal for the card to be scorched.
M
MattieC
Likes
#9
Hi Rolf
Ill try and reboot it later on and let you know what happens
Matt
S
solsat
Likes
Alicante
#10
MattieC said:
Hi Rolf
Matt
You may have water ingress in the cable at the lnb end. Try cutting back the cable 6 inches and remaking the joint.
