Pace digibox distribution problem
sdavies182
Pace Sky plus box with 93 cm dish
Hungary
Currently use a Pace DS445NB which I believe is a wideband receiver and this works fine for most free to air stations with a 1m dish
Connecting the DS445NB up to the one LCD using a coax cable is fine.
However I have a problem with the RF coax signal out when I need to distribute the signal around the house using a standard 8 way splitter
My previous Sky box which wasn't wideband worked fine thro a 8 way splitter - is it a case of newer Sky boxes are being produced which makes them less compatible with splitters ( and so forcing punters to buy additional Sky boxes and use their multi room subscription ? )
If so I am on the look out for a good general purpose wideband receiver ( no need for Sky plus ) which will work with a splitter
Can anyone recommend a good receiver which I will be able to pick up on ebay ?
thanks
Sorry not sure what you mean by wideband receiver, the Pace Sky digibox is no different in general specification from any of the other Sky digiboxes. It may be that your earlier digibox gave a slightly higher RF out signal than the Pace, but most digiboxes would struggle to provide enough RF output to use an 8 way splitter, the through loss of which must be more than 10db.
To solve the problem simply install a small launch amplifier.
