poor sound/ itv
telly2
Visit site
I have poor sound on itv this afternoon anybody else suffering the same today.All other channals ok
iceman
3.0m Motorised Channel Master + 4 fixed dish Amstrad_DRX890C
DM7020s,DM800se
UNOHM EP314 PROMAX TV Explorer
Kyrenia - NORTH CYPRUS
Yes i also had same problem on ITV yesterday...(havent checked today)
iceman
Another problem I have sometimes noticed with ITV is that occasionally the sync between sound and vision goes very badly adrift.
This is a problem with satellite transmission as when I switch to terrestrial it isn't there (or at least only very slightly as per normal).
Razor
Retired Mod
Ireland
I also found that when the weather is bad the sync of sound and picture goes. If you zap up or down one channel and then back, this will normally fix the problem. Also if you are watching live TV the sync can be way out. As to why this happens, beats me.
For live tv such as news programmes I think it's because it takes more processing power to online digitise and squash a video signal than it does an audio signal.
For a pre-recorded (offline) programmes the system can take a fraction longer to make sure the sound and vision are reasonably in sync (although sometimes I think the engineers don't bother).
The sync problem can be generated at one or both ends of the link
PaulR is correct that the compression used can affect the way sound and vision syncronise in the datastream, however the receiver in the house has much work to do by resolving the two outputs to the satisfaction of the viewer, by virtue of the information supplied with the data, which may have errors as a result of low signal (poor weather), increased noise (misaligned or too small a dish/leaky LNB/cable). Then there is the receiver firmware itself - many people will know the problems that continue to plague the cheaper end of the receiver market and likewise Manhattan 2500 and 5500 receivers, the lips move but the sound follows a second later, listening to classical music on these receivers can be a painful experience
