Ppua
radiotech
USA
Hi to my understanding the PPUA is in a viaccess subscribed card. Is there any other way to obtain a PPUA by logging? I have ident, op. keys only. Thanks
Thanks Marcoh64. I know that i don't need the PPUA if i have a working opkey. Just in case they change the opkeys, then i need the PPUA to obtain new keys.
You will need a litle more then just the PPUA m8.
For a good understanding on how key updates in Viaccess work, how to read log or how to extract an original card, i suggest you have a look at the FAQ (and the mainforum) at http://vkeysforum.page.to
would i get the new opkeys if i have issuer's mk 00, mk 01; subscriber's mk 00, mk 01 and mk 04 and PPUA. To my knowledge, i need to have mk 05 + PPUA to get new opkeys. Thank you in advance.
This depends on how the provider is updating, and since you don't state the provider you are talking about, i can't answer you.
provider ID 011400 (taipei international) and provider ID 017400 (asia after dark). Both are USA providers. Another question, can i log new keys (mks or opkeys) using information from an unsub card? also the issuer for taipei is FFF600 and issuer for AAD is FFF6F0. Thanks in advance.
