Remote Control Of Satelite Receiver
PACH
Technomate TM5200 Satelite receiver + 80cm dish +1LNB.Direct coax link from the receiver in the lounge to a bedroom TV
North Yorkshire
I had the following system installed : Technomate TM 5200 satelite receiver + 80cm dish with one LNB. The receiver is connected to the TV in the lounge and a coax cable is linked from the receiver to an upstairs TV. The original spec that I required from the installer was that I needed to be able to change channels of the receiver on the bedroom TV also. Unfortunately the installer did not manage to get the remote option working,let down very badly, so now the only way to watch a certain satelite channel is to change it in the lounge.
Can somebody recommend a simple and not very expensive system that I can install to do the remote channel change?
Thanking you in advance.
mariust5
Cristor Atlas 100HD , motorised 1.1 Triax on Stab H-H
hastings , uk
_http://www.ebay.co.uk/itm/One-for-All-SV1715-TV-Audio-Visual-AV-Sender-/330805107591?pt=UK_ConsumerElectronics_WirelessVideoTransmitters_CA&hash=item4d05855b87
PACH
North Yorkshire
Thank you for your reply. I understand that there is a lot of interference using wireless option and as the receiver is already connected by coax cable to the second TV there will be anotheroption.
Burnham Beech
The Omni link system works very well. It uses the coax cable you already have connected to your second TV.
It uses the same system that Ѕky uses for their magic eye version, but can be used with any satellite receiver.
pgh13
Midlands UK
So How about this again on E__y? 170925522410 Just transmits the remote signals
