RO.VE.R Rover Satellite meter software
AndyW
Rover tda6
merseyside
Good evening.Slightly off topic but could please someone help? I have a rover tda6 meter and today in the middle of using it the screen went blank but power(backlight) stayed on.I cant turn the meter off or get it to do anything.Any ideas?
ps.This has happened once before in the past but turned off and on straight away.Also ive no manuals for the meter so i havent a clue whats possible.
Thanks,Andy.
developers
www.development.plus.com
Vu+ Solo 4k PVR using Enigma2, Motorised Triax 1.1m, fixed Orbital 80cm dish with 3 LNB 13e, 19.2e and 28.5e 4/1 way diseqc Cas 3+ Diablo 2.3 & TRex 4.6 Rover SDM2 & Satlook HD
Cheshire.
SDM2 hardware reset is by press and hold power (on/off) button for 10 secs. It should also reset if the battery goes flat enough. Good luck!
Emphatic
90cm dish Sharp Dual LNB Optus C1, 1.2m dish Sharp single LNB Optus D2
Australia
I got impatient, so I sent the SDM2 to the supplier to write all 99 channels for about A$88, with 1 day turn around
developers
Cheshire.
Sorry I couldn't help but whilst your PM wasn't available and your email address was removed. If you do need help in the future customising the list etc let me know.
Jem
AndyW
Rover tda6
merseyside
Thanks for the help.The battery did run flat so the meter reset.I'll try the other option if it happens again.
Thank you.Andy.
developers
Cheshire.
Hi Satwino
Thanks for the PM. Glad you can now program meter with transponders yourself. In the SDM2 programming the High Low column refers to the frequency band see _http://www.digitalsat.co.uk/astra2freqplan.html for instance. Each sat may use different definitions of High or Low so best to check.
Thought it best to reply on the forum so all can benefit if they have the same query.
Regards
Jem
developers
Cheshire.
Sorry mhku I know the rules just forgot to use my head when reading my typing - thanks for the edit
5z4es
VSAT INSTALLER
KENYA
developers said:
By the way I also have a few of the chips available (just the 16 pin micro interface chip) as specified on the wiring diagram so if anyone wants a chip and wiring diagram with pin outs to build their own they are just £2.00 each.
Hi thank you for your post and to all other here in the forum.
I here in Kenya and wonder if you could just post the pinout of the small RJ connector, the rest i can do it here, it is simply a RS 232 to TTL converter.
You could also use the cable used for the Nokia 3310 duly modified, but surely at a cost more expensive than 2 Pounds.
Kind regards
Enrico Li.
Sat uplink broadcaster engineer.
developers
Cheshire.
I'm not commenting on your suggestion as I don't know! but the pin out I used was
Meter
01 TX
02 RX
03 Reset (8ms to ground) unused
04 +5v
05 Boot for firware upgrade (=5v to ground) also unused
06 ground
jasmine1
echostar 2110 2ci/echostar 808 via 2ci/matrix reloaded/opos 105/titanium/vr3/fortec HD/Quali HD/diablo/DB500S/110cm motorised
midlands.UK
Hi guys,i have 1 of these meters sdm2,mainly use it for 19/28 and 13 hotbird,was wandering if any1 knows what the others are like 352 355 and 330 in the meter,any help please hoping it has 1 west somewhere but can not see it,current software vers is 1.05,thanks
developers
Cheshire.
Hi Jasmine1
352 = 8 deg west, 355 = 5 deg west and 330 = 30 deg west. I thought standard set of transponders included 359 or 1 deg west but if not you'll need a lead and software as above or send the meter for an update. 1.05 is not the latest firmware (transponder lists can be addded at any time and do not show on start up) for the meter it's 1.10 on mine when on the start up screen which might need updating to see newer sats (I don't know!).
I'm just putting the final touches to my new transponder list, updating changed frequencies and adding missing sats which will use about 75 of the available as well as making a new matching crib list with the instructions as came with the meter to give all the usual sats between 45 deg w and 45 deg e.
Jem
jasmine1
midlands.UK
Hello developers,just wierd as to why 359 1 west is not in :confused
developers
Cheshire.
Do you have 50 entries at the moment? my old list did and that had 359. I've attached the list that came with the meter, some entries are out of date but it may help you start your own if you don't want to send it away. 1 deg west is popular for the footie I understand but I've not tried it.
Jem
  • Channel Satellite Instrument Files .zip
jasmine1
midlands.UK
Jem
Hi jem,thanks for the list but havent got any software to open it with,plus no manual for the meter so dont know what iam doing to be honest.
developers
Cheshire.
Jasmine1
I've Private Messaged you if you check your inbox on the forum.
Jem
wh1tey
New to this and I am just starting so when i'm set up i'll change this
Bolton, Lancashire
Hello if anyone still has the wiring diagram fro the sdm2 update lead then id love to have a copy of it so I can make my own cheers .
bro
DM500S MOTORIZED
ENGLAND
could you pm me with the contact info please as a friend needs one of these leads
thanks
developers
Cheshire.
Sorry for the delay I've been away but I do still have a few of the chips available but I can't private message you yet as I think you need at least 5 posts.
andyntl707
satellite & aerial
lincolnshire uk
hi has anybody got an instruction book,or know where i can get one for sdm2 meter
thanks
andy
developers
Cheshire.
I have something called a user's guide, 12 sided a5 booklet which I could photocopy and send but I don't know where you'd get a download.
Let me know via my website (see contact info in the profile for my username) if you need it.
Jem
