• This site uses cookies. By continuing to use this site, you are agreeing to our use of cookies. Learn more.
satellite programs in english
Likes
gb sat
derby
#1
hi ive been searching for the name of a site it lists the tv programs thats available on the various satterlites.it sounded like lyngaurd?any help please.also if i switch to a twin lnb what programs could i expect to receive?as you can tell i'm a complete novice.
regards leadshot
Likes
TELEVES rds 7254 DVB 2000, motorised 1.2mtr diseqc
North West ENGLAND , Rochdale OL10
#2
u are probably looking for lyngsat.com that has a good list .
Robbo
Likes
5
Gravesend,Kent,UK
#3
regards leadshot
A 'Twin' LNB will give you no more tv programmes than a standard single output LNB. It is designed so that you can run two receivers from one LNB, or a _Sky plus box which has two receiver built in.
A 'Dual' or 'monobloc' available in 6 degree and 3 degree varieties will enable you to receiver two satellites from the one LNB with the sats
6 degree or 3 degree apart respectively.
and Yes it's lyngsat.com that you want, there are also lists on flysat.com and _http://en.kingofsat.net/
there may be others also.
I have found that sometimes one site doesn't contain the most up to date info, and it's worth checking one of the others.
Lyngsat I have found though is the easiest and clearest to navigate.
