setting receiver help
D
den123
Likes
16
ddcccccc
uk
#1
hi do i have to set the motor with the frequences then do the chanel search after then store them in. i have stored chanels earler have now lost them think i might be doing somethin wrong i have a humax 2000hd reciver going get a tm1500ci monday thanks guys for all your help what a great site thanks:confused
Likes
3,456
den123, try to stick to one thread in your quest to set up your Humax and motor. You're all over the place in this section, otherwise it's difficult for you and those trying to help otherwise.
You set your motor with your locality's coordinates using the Diseqc 1.2 or USALS function in the Humax Antenna Menu (before you do any channel searching).
D
den123
Likes
16
ddcccccc
uk
#4
hi guys have finale finished the set up with your help can you please tell me how many satelites i should pick up from where i am in the uk exeter thanks again :-rofl2
D
den123
Likes
16
ddcccccc
uk
#5
how many satelites should i pick up in uk thanks 1meter dish ect motorised
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#6
check out lyngsat for foot prints etc;)
D
den123
Likes
16
ddcccccc
uk
#7
can you explain mate footprints ect i live in exeter
Topper
Topper
Amo Amas Amant Admin
Likes
3,365
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#8
Try to imagine a torch beam coming out of the transponder and shining on the earth, each transponder has a footprint so go to here select your satellite as in here then look for the column called beam and click on the blue name to display that transponders footprint as here for Astra 1G
Topper
Topper
Likes
3,365
#10
CROSSBONES
CROSSBONES
Likes
190
S.Wales
#11
well explained Topper m8y;)
