Settings for THOR 1W
mick2me
www.nottstalgia.com
'Fortec Star Passion' (& a dead SL65) One of them big Woks on the outside, and a thingy that moves it about a bit.
Nottingham
I am located at 1W
I want to use THOR 1W for setting up my dish motor
The SL65 receiver does not have THOR 1W setup in its memory.
What settings do I have to input in the SL65 for adding THOR 1W to its list of satelites?
Mick T
mick2me said:
I am located at 1W
Mick T
Just modify the settings for one of the Asian birds you will never use.
J
Jeff_19341
Hi mick2me
Does your receiver have a satellite named as "Intelsat 10-02"?
If so that is the other bird to use at 1*west.
lordgarretty
BskyB and PC
Is there anything worthwhile on Thor - without a legit sub?
Rob
Technomate TMS-1500 CI+ "patched" receiver, 90cm p/f 36v motorised dish, Inverto C120 0.3db LNB, Moteck V-Box 2, Packard Bell 6052 XP Home computer, Toshiba A60 laptop, and lots of Russian Vodka !
Essex
Check this out my lordship :)
http://www.kingofsat.net/en and then click on Thor and it will show you everything on there, that's Thor 2 & 3 and Intelsat 10-02.
All depends what you call worthwhile, but I think it's a pretty dull sat.
Give it the :-Guill
jakenl
Manhattan Starlight 5900+PVR-80GB,Topfield TF5000CI,Skystar2,110cm dish, Invacom 0,3dB, Moteck SG2100A,range: 75East-61West,AMD Sempron 2600+, Windows XP Pro.
The Netherlands
When I read it correctly, the channels on Thor are of no interest to him, he just wants to use this sat to set up his motor, right?
Go to your settings menu, choose Add satellite, use a transponder with constant signal, f.i. 11247 V, 24500 7/8 (Telenor) and turn the mast with motor fixed at 0 degrees until signal is received and tighten mast. Search for channels if you want and save.
Goodluck.
Jakenl
mick2me
www.nottstalgia.com
Nottingham
Goodluck.
Jakenl
I havent got a clue whats on THOR, but its due south of me, so best for motor setup.
Thanks for the replies I will peruse the info and hopefully it will help me with my problem.
Intelsat is not pre programmed? I take it this is a different sat at the same location? 1W?
Lancelot
Retired Mod
SS1.
36v H to H 62E - 61.5W
South central
Have a look HERE.
Useful little tool. You will need Acrobat Reader though.
L. :)
Rob
Essex
jakenl said:
When I read it correctly, the channels on Thor are of no interest to him, he just wants to use this sat to set up his motor, right.
Wrong, that post was for the post in front of me from lordgarretty not the original one from mick2me.
"Is there anything worthwhile on Thor - without a legit sub".
jakenl
The Netherlands
Okay, you got me there, Rob.
Indeed my reply was ment for Mick2me.
Sorry.
Jakenl
Rob
Essex
No problem Jakenl, we welcome your input. :)
mick2me
www.nottstalgia.com
Nottingham
Thanks for the PDF Lancelot
Very useful
I dont have Intelsat as mentioned?
I am a novice so I am not sure what I have to input for new satellite properties?
misterminibus
Lancashire
Kodi
Lancashire
Hi mick have you got anywhere with a patch yet?
I have come across someone who says he can get multivision 1-7 which are excellent movies and tps which is a bit like sly 1 and stuff.
check this out.
_http://www.gccadm.net/forum/viewtopic.php?t=40153&postdays=0&postorder=asc&start=0&sid=36b54026d11e592bbeb51a216a0a4634
looks hopeful
Regards
Daren
