Sirius 4 setup - help !!
agreen8
just sky+
uk
I am new here so apologise if there are more threads on this. I have treid searching.
I am trying to setup Sirius 4. I live in Peterborough and have an 80cm dish. I simply cannot get a signal at 4.8/5 degrees east.
I can get hotbird (13 east) so I know the LNB is working.
Is there a problem with sirius satellie installations. I even got a "pro" round and he could not get the satellite either on his expensive meter. He did say he has had problems with this before.
According to all the maps I have seen, an 80CM dish should be OK. The dish is about 3 meters off the floor and does have to clear a house. But according to dishpointer.com I sould be clearing the house easily. Indeed Sky has to do the same thing and is at a lower elevation.
Any hints / tips on locking onto this satellite.
Thanks in advance
Tony Green
Try looking for the Ukrainian channels on 11766H 27500 3/4. They are probably the easiest to find. Or the new Swedish mux on Thor 2 11247V 23145 3/4. This one is easily as powerful as Astra 2 28E!
Park Royal
Smart lnb, 1m Gibby dish, Stab motor, TM5200D receiver, 57east to 61west. DTT from Sudbury. Virgin Media broadband.
So called capital of Suffolk, UK.
A good strong transponder here is, 12380H, 27500, channel named LTV World. S&Q at the end stop.
But of course I do not use a sky+ set up
Parky
agreen8
just sky+
uk
Thank you found Sirius 4 with your help. Greatly appreciated.
Nice one ag - enjoy the extra channels. :)
