Sky+ Box with only 1 dish antenna
M
Mombos
Likes
Hello All
We have had sky+ for a while now, we also have a extra box in the bedroom upstairs costing us god knows how much every month,
i recently brought another sky+ box so we can have it upstairs aswell as downstairs, i spoke to sky and they said the box will work,
although i didnt realise that the sky+ box has 2dish antenna inputs,
our box upstairs only has one, is there a spliter i can buy that will split the one cable into 2, so i can have both inputs used and use the sky+ box upstairs the way it is meant to be used.
Thanks in advance
Rob
M
Mombos
Likes
Ok
i have just spoken to a guy at SKY, who tells me it will work ok with just 1 antenna but i wont be able to dual record or anything,
he told me i need another LNB for the 2nd signal for the sky+ box, are these self fittable because i dont really want to pay sky to come out and fit it they will probably charge me a fortune.
if anyone can offer any advice on this it would be greatly apreciated,
cheers
Leee
Leee
Likes
Sky+ v2 (120Gb); DM7020Si*motorised; PC/S2-3200
47°N/8°E/490m
#3
replacing LNB should be straightforwards; more time-consuming would be the second cable run....
where's your dish located? What route does the existing cable take to the box?
M
Mombos
Likes
distance from the dish to the box in the bedroom is about 3/4metres - it just literaly just next to the room the box is located in, they drilled straite through the side wall to the dish, so i take it wouldnt be to hard to drill another hole for another cable,
how much would sky charge for this just out of interest?
cheers
Likes
1,291
#5
If you already have a Sky+ and standard digibox running, then you must have a quad LNB already, this being the case, all you need to do is run the extra cable and enlarge the hole in the wall to accommodate a second cable. Most installers would probably charge around £45 for this, but if you have a drill it is pretty easy to do yourself. :)
M
Mombos
Likes
is it just a case of plugging the new cable into the bottom of the LNB? i might have a go if its that easy, will there be a spare port to plug the wire into? i had a quick look i can see 3 cables coming from the bottom of it currently.
cheers
Rob
BGonaSTICK
BGonaSTICK
Likes
Dreambox 7000, Skystar2
Brighton
#7
Yes, that's right. 2 per box. Waterproof your connection(s) properly!
Topper
Topper
Amo Amas Amant Admin
Likes
3,342
IDD CI24 ECONO MM Penta 1.20 Galaxy II
1.2Mtr Polar MTG yes it has been on the arc for 25 years and is now fixed on 13 East using two pairs of rusty molegrips. Unlike me they never groan but always perform.
Blackburn, Lancashire
#8
Use the proper self amalgamating tape not electrical insulation tape
Likes
1,291
#9
Most of the newer quad LNBs either have rubber gaiters or a slide down plastic rain screen, so the water proofing is easy as well. :)
If it is the rubber gaiter type, make sure that you do not move the dish whilst pushing it on.
