SkyUK premium ch recording with DB7000
gsmserv
gsmserv
DreamBox7000s120HDD,MMv1.05,Fun6,CAS2(add-on)90cm satellite dish,2LNBsDISQ,BSkyB dish,HP Pavilion dv1000 Intel Pentium M processor 1.60GHz 512 MBRAM 60GbHD DVD RW,1 Mb broadb,LAN,PanasonicSA-HT520 home cinema system,28"JVCflat,wide.
ENGLAND
hello,
is it possible with dreambox7000 and SkyUK card to record Sky Movies,Sport and FTV channels to Harddisc and later to PC and DVD?
I use gemini 2.10 ,newcamd6.01, camd3 3.781
gsmserv
gsmserv
ENGLAND
nobody knows?
i have used search in forums but didnt find anything about that.
if it possible i would like to order sky.
any idea, please.
thank you
W
wallycharlo
DM800 / 1m Gibertini XP
Western Austria
It is possible to record from S*Y to DM7000 HD. But, some people (I am one) get problems while doing this ; if you are watching the same time as you are recording, the picture freezes a lot, which is a real pain. However, it does appear to record correctly nonetheless.
Once you have a recording on HD it is then possible to transfer this to youre PC, and then to create a DVD, etc, from it.
JTA
JTA
DM8000HD+DM7000S with PLi image, CCcam, movable dish 0.85 m, very happy indeed
Belgium
I often record one channel while watching another (on the same transponder) or watching another recording, or the actual recording itself (delayed viewing), I've never had any problems with hiccups or freezes on my dreambox (gemini 1.8 with newcamd 6.1 and betad). You can transfer the files to your pc afterwards (with dream vcr or the gemini manager) and watch them with mplayer (part of gemini manager or dream tv). There are other tools to convert this file to a DVD, but I've never done this, but it should be possible.
W
wallycharlo
Western Austria
yes, newcamd6.1 has a fix for the freeze, but i need to use the cardserver from 5.28
john_graydon
john_graydon
Dublin....Ireland
I think if you upgrade to 6.1 it still works you dont have to update the cardserver. I didnt update mine as far as i remember. Copy your image with the 5.28 and then try to update via control panel to 6.1. If it dont work just tranfer the 5.28 image back.
T
tallguy74
db7020
3 LNB (ast1/ast2/hotb)
c+ NL
SDT Davinci
nl
Maybe it's an idea to use newcs instead.....
Seems to work more stable then cardserv....
If you need help installing, just let me know.
W
wallycharlo
Western Austria
thanks for the suggestions john and tallguy.
i need to use 5.28 cardserver, as it enables sharing. i cant use newcs as i need gbox for our network, and use cs2gbox as a link between the cardserver and gbox
T
tallguy74
db7020
c+ NL
SDT Davinci
nl
Well , you can still use newcs, and let cs2gbox log into that one....
Newcs also opens a newcamd server port , just like the org. cardserver does....
And you can then just let cs2gbox log onto that port that newcs created.
STBs = Ultimo4K, VUDUO2, VuSolo2, Alien2, AzBox HD Elite, ET8000:
Dishes = 180cm PF, 80cm offset, 60cm offset, Sky mini:
LNBs c120 for PF dish = Ku-Band White Smart Titanium (modified to c120)
and for C-Band Titanium C1W-PLL
Yes,
NewCS => cs2gbox => gbox
works fine :)
Z
zamolxes
1M dish
Valencia, Spain
No luck here with newcamd-betad 6.05 on a gemini 2.60, dm 7020, if switching to another channel, the recorded image freezes after 40 seconds or so.
BGonaSTICK
BGonaSTICK
Dreambox 7000, Skystar2
Brighton
Are you sure that the second channel is on the same transponder and not just the same satellite?
Z
zamolxes
1M dish
Valencia, Spain
Someone suggested Mgcamd/newcs on another forum and yes it works perfectlyy!!
BGonaSTICK
BGonaSTICK
Brighton
LOL, OK I guess you're happy with that then :)
S
slayter
Dreambox 7000
1mtr Dish
Hi gsmserv
I've got a 7000S with an internal HD and I use my Sly free to view card and premium cly channels card in my box and record fine. I am using SDT latest image 5.2 and Newcamd 5.28 emu (and cardserver)
With this set-up mate you would have no probs with recordings. Depends how attached you are to the Gemini image.
I've tried pretty much all images and am a big fan of Gemini but in my opinion SDT blows it away. (note: just my opinion:p)
Let me know if you want anymore info.
Slayter
PS - Don't talk to me about the grief I've had trying to get a decent set-up recording on my 500S CIFS - now thats a completely diferent story 'O'-red
