Some way of setting a dish up
fergyc
VU+ Duo with ViX and OSCAM, Prof Revolution 7301 PCI Card, 2x Dreambox 500S, 80cm Technomate Dish with Inverto Black Ultra and TM-2600 DiSEqC Motor. Technomate TM-300D along with a few zone 1 minidishes that get moved regularly and a zone 2 for 19e a
Northumberland
Moving into a new house soon and it's rented so I won't be able to have a dish on the wall. There isn't even a front or back garden/yard so I'm stuck for some place to have the dish, looks like I may have to try some kind of window setup unless anyone can see something. Mine's on the left
satelliteman
Depends on LOS but you could try a patio mount in the garden ;)
fergyc said:
< There isn't even a font >
That's not unusual, though!
smoggy07
Nextdoor have a sky dish, ask them if you can run a feed off that
That way you`ll still have a feed to 28 untill you can figure out where to mount another elsewhere
Can you not bolt it onto the metal fence outside the front door or would there be no line of site?
Robbo
Retired Mod
www.mbcsatellites.co.uk
Gravesend,Kent,UK
On the railings at the front?
Cormoran
1m Gibertini + Titanium LNB + New Horizons NH-210 motor, 65cm Als*t + Megasat Diavolo LNB, TMS-1500CI+, 60cm minidish + octo LNB serving 2x Amstrad Sky+HD digiboxes and 2x Bush HD Freesat receivers (Don't laugh, they do the job!).
Norfolk
Rented, eh?
How much of a liberty do you think the landlord might allow you to take?
If you can't even bolt a dish to the wall my idea might be 'a little extreme', not to mention potentially daft!!! (I'm sure the boys will tell me how daft soon enough....).
So, how about removing the opening sash of one of the bedroom windows and replacing it with some thick (1" or so) external grade ply? Weather-proof it externally then bolt a 'J' mount on to it.
Not sure how stable it would be but could be better than nothing.
S'pose it could also result in the window succumbing to gravity if it ain't fitted very well! :eek:
You'd have to do without your motor too.
So....
NEW PLAN -
Talk your new neighbour into some nice, new, shiny, T & K mounts with room for their new 60cm minidish (bribery) and your dish/motor????
I'm going to go away and be quiet again now...........
Think I might have reached my senile phase! :-ohcrap
PS. You sure you want to move in there anyway? Looks like the house next door is on fire!
Knock an 8 foot long square section fence post into the ground up against the wall and bolt the dish to that.
2 x normal tv aerial brackets will bolt to them nicely with some pipe between them - Ive used them for years
Cormoran
Norfolk
Like your thinking but wouldn't it be easier just to thump a length of scaffold pole in instead?
(By the way - why, when I used "Reply with quote", did the second sentence of your response suddenly appear?? Spooky).
Possibly easier yes, depends what the ground is like and if he can get scaff poles of an appropriate length. - I wrote the 2nd sentence after I posted to clarify the point :)
RimaNTSS
Some SAT-related hardware.
N-E from Riga
This one could be sticked to glass. No holes, no bolts.
Terryl
Custom built PC
It would be better to use an "Non-penetrating" roof mount, it's held down with some concrete blocks, no holes in the roof to worry about.
They have saddle types that straddle the peak of the roof.
fergyc
Northumberland
Thanks for the ideas. There's nothing at all, it's practially on the road! Only taking the minidish with me so it won't be very heavy.
Next doors Sky dish is a single LNB...but I do have a quad in the drawer ;)
Railings mount of the fence post trick would work well but I could wake up in the morning with the dish missing!
You must not make any alteration or addition to the Property, install your own fixtures or fittings, or do any redecoration without our permission in writing (which we will not refuse or delay without good reason). You must reinstate your alterations prior to departure or you will be liable for the cost in completing this.
smoggy07
That doesnt say you cant put a dish up, it just means you have to ask them in writing first, I`ve had that with an old loandlord and he was fine about it aslong as I left the minidish up when I moved out
Tell them you use it to watch God TV and other religious broadcasts
Terryl
Custom built PC
Take a look at this puppy.
_http://www.amazon.com/VMP-PRM-2-Non-Penetrating-Pitched-Mount/dp/B002JM1P7Y
Whats at the back?
Just as a matter of interest why does the top pic make it look like the right hand flat is on fire or has the roof been hidden in a Bermuda Triangle like fog bank??
Terryl
Custom built PC
Someone forgot the steaks on the BBQ?
RimaNTSS
N-E from Riga
Looks like Photoshop edited picture.
Cormoran
Norfolk
I wish to make it clear that I am not, even a tiny little bit, hurt by the fact that my PS. in post #6 has been totally disregarded by EVERYONE!!!!!!!!!!!!
satelliteman
Looks like some dirt on the lens.
Anyhow as mentioned, what about a patio mount on a couple of slabs. Should be enough room at the front.
