willo30
- Sep 22, 2009
- Age
- 54
- Sky+HD.
- Wirral, UK
Hi, this is probably a really stupid question but here goes anyway.
Is there any way I can check too see if I can get any satellite signals with a meter or something before actually buying any satellite equipment.
The reason I ask is because I am not sure I will be able to get any signals in the only place I can set a dish. The problem I have is that the signals seem to come from over my house and the furthest I can get the dish away from the house is approx 18m. Another problem is the max height I can probably raise the dish is about 6ft due to a very large tree next door which the neighbour has kindly said I can take some off but the dish would still need to be pointing from below it.
As you can see I do not want to go out and spend hundreds of pounds to find that it won't work.
Any suggestions would be greatly appreciated.
