Unable to receive channels from NSS 22w Satellite
saalim
dreambox dm500-s
ghana
My dish is fixed on NSS 7 22.0W. Am able to scan some frequencies like 11551/30000 V. But when I scan 11491/30000 V I get no channels. There are lots of channels on that frequency too. Can someone direct me on how to get more channels on 22.0W?
Thnks
The transmission parameters seem to be the same for the two frequencies, and both are on the west Africa beam
The first thing to investigate is any local sources of interference that may be blotting out one frequency - for instance - do you have a digital (dect) phone? If so switch it off and unplug the base unit as well and see if that makes any difference.
saalim
dreambox dm500-s
ghana
sorry for late response. i had a power problem for the past three days but thank God i have power today.
back to the topic i dont have any digital phone in my house. and i still dont understand why i dont get channels from that frequency. is there anything else i can try?
thanks
According to KingofSat, they're not active frequencies, just occasional feeds. Can you still scan in anything anything on 11551V?
saalim
dreambox dm500-s
ghana
when i scan 11551v i get about 22 services. there are about 27 or more services on 11491v but i dont even get 1.
OK, checking Lyngsat I see 11511V is now on stream with the CanalSat Afrique package. Nothing there shown for 11491V, but as I am out of the footprint of the West Africa beam, I'm afraid I can't help you any further.
saalim
dreambox dm500-s
ghana
on same site also i saw this _http://www.lyngsat.com/packages/canalsathorizons.html. which includes 11491v. it is unfortunate u cant help but i hope something can be done.
thanks.
Topper
Amo Amas Amant Admin
Blackburn, Lancashire
Anything that interferes with the signal path can block a frequency. As you have not filled out the system details fully we can only guess what equipment you have got, as regards dish and feedhorn lnb assembly etc. For example is there something nesting in the feedhorn? Is the cable damaged and ants now nesting in the cable. What grade of cable are you using, is the cable foam filled dielectric or airgap dielectric. Is there water ingress into the cable. Is there a WIFI repeater nearby More information required in order for someone to help you apart from the meagre information that has been given
