Mohd Sadoon
- 240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
- Oman
Hi guys how are l bought gibertini 1.5 also I want to buy good and sensitive lnb and I want your advise to guide me to buy good lnb
I bought gibertini feed horn but it don't arrive until now maybe take two weeks to arrive but I don't know which lnb working fine with gibertini feed horn also l need your advice to guide to get best lnb and thank youBut cheap enough to replace. You CAN also try Gibertini feedhorn with a C120 LNB.
It really depends on what you are trying to achieve.I bought gibertini feed horn but it don't arrive until now maybe take two weeks to arrive but I don't know which lnb working fine with gibertini feed horn also l need your advice to guide to get best lnb and thank you
HiIt really depends on what you are trying to achieve.
Fringe reception? Multi-LNB reception (multi-focus)? C-band?
For general tv reception, even slightly on the fringe, most modern universal (integrated) Ku-band LNBs will do the job.
Can you be a bit more specific about what you want to receive?
Hi
I want for ku band
Yes but what sats and what beams are you trying to receive?Hi
I want for ku band
I want to try Astra 19 east Europe beamYes but what sats and what beams are you trying to receive?
North OmanFrom which area ?
In your opinion which ku lnb will work fine with gibertini feedhornNorth Oman
Yeh just tryThats quitte a distance !View attachment 116517
Yeh I know that wide beam it's receivable in Oman by 90 cm dishFor sure not all beams can be received, but Europe Wide beam is possible (according to Satbeams) . So, worth to try.
