Which is best lnb working fine with gibertini dish 1.5 m
Mohd Sadoon
240 cm PFA - 180 cm PFA - 120 cm PFA
Coverage 14W - 125E
Oman
Hi guys how are l bought gibertini 1.5 also I want to buy good and sensitive lnb and I want your advise to guide me to buy good lnb
RimaNTSS
Some SAT-related hardware.
N-E from Riga
Buy Inverto Black Ultra (IBU). It is good and sensitive.
The Invertos appear to have a finite life when fitted, two to three years.
But cheap enough to replace. You CAN also try Gibertini feedhorn with a C120 LNB.
RimaNTSS
N-E from Riga
I am going to buy brand new IBU soon. Then I will be able to compare it's performance against oldest IBU I have (~ 7 y.o.) Of course there are at lest 3 options of the test:
- new IBU outperforms the old one;
- old IBU shows better results than new one;
- they both perform more or less same.
Something tells me that it will be option #3.... when they perform equally good or equally bad :-rofl2
TJExcalibur
Out of this world.
Southern England
OK to buy the considered best LNB but for many the difference would be hardly noticeable and as in my case who wants to change an LNB if accessing the dish is difficult.
Mohd Sadoon
Coverage 14W - 125E
Oman
I bought gibertini feed horn but it don't arrive until now maybe take two weeks to arrive but I don't know which lnb working fine with gibertini feed horn also l need your advice to guide to get best lnb and thank you
archive10
It really depends on what you are trying to achieve.
Fringe reception? Multi-LNB reception (multi-focus)? C-band?
For general tv reception, even slightly on the fringe, most modern universal (integrated) Ku-band LNBs will do the job.
Can you be a bit more specific about what you want to receive?
Mohd Sadoon
Coverage 14W - 125E
Oman
Hi
I want for ku band
Mohd Sadoon
Coverage 14W - 125E
Oman
From which area ?
Trust
Nijmegen Netherlands
RimaNTSS
N-E from Riga
For sure not all beams can be received, but Europe Wide beam is possible (according to Satbeams) . So, worth to try.
Mohd Sadoon
Coverage 14W - 125E
Oman
Yeh I know that wide beam it's receivable in Oman by 90 cm dish
But I want to try Europe beam
