Why Us Again ??
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Tivù said:
I'm sat in the back catching up on my Crosswords owing to the foul weather and I can see my 80cm Motorised flapping about like a Seal on speed.
Good luck Gordon ..
I hope your dish survives ..
Its that oscillation that convinced me to stop using the edge on approach ..
If the brackets are well secured ...I'm convinced its better face on or better still ...rear on to the bulk of the wind..
rgds
VS
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
Lol ..
Nice one CH ...
an endless supply of water here ..so no rush ..
I could try catching some pummice and ash ..if you need any ...
_That_ should be arriving from the West ..tomorrow or the day after..
rgds
VS
Flat calm here:
_http://uk.weather.com/weather/today-Alicante-SPXX0008
Ah, but we are not plagued by asps ...............
"asps"??? :confused :confused :confused
No plagues here at the moment either.
You have on a number of previous occasions mentioned snakes ..................... Something the heat (of which you generously remind us semi-eskimos) tends to bring out :)
sonnetpete
wordpress.com
Normandy, France
No sign of gales, rain, asps, frogs or locusts here. No volcanic ash cloud either (it's bound to come up sooner or later). Lovely clear sky, a bit breezy with temperatures in upper 20s (°C)
If it does get windy, I try and move my dish edge on to the wind but may think of doing otherwise in the future.
The ash can bu**er orf - we're flying from Leeds to Alicante a week on Saturday!
Fortunately, the wind is beginning to abate: It peaked about an hour ago and was accompanied by a heavy squall of horizontal driving rain.
Dishes look intact, but will do System Operator Checks when I get back from the Doc's.
OldBen
Mad Scientist
Triax TD110 with multi LNB 28.5E, 23.5E, 19E, 13E Inverto Black Ultra's (Black Premium on 28.5) into multiswitch. VU+ Duo. Emitor Satlook Lite meter.(Retired: Technomate 1500CI+, Moteck DG2100 DisEqC Motor, Metronic 85cm Clear Dish, Invacom 0.3db LNB
Lots wind down south, few branches down on the way back from lunch and plenty of tree debris in general in the road, so the soft southern pansies taking a battering as well (my TD110 is still in a box in the garage, safest place for it? ;)
A nonymous
Well fortunately my motorised Penta 85 survived the wind without as much as a murmor :D
My 60cm Channel master moved slightly which i found quite odd as i had to really slacken the bolts off to move it back. It still worked but the BER was creaping in a little so i thought i'd better line it back up again this evening.
Nano
All dishes intact despite the ferocious squally weather yesterday :)
satelliteman
Nano
Maybe, just maybe.... it wasn't aligned up properly when installed :D :p ;)
Probably the knackered ST4 :-rofl2
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
..worth checking that the lnb arm is still at right angles to the dish plane ??
if its moved about half an inch off vertical ..it can be equivilant to a 1 degree shift in the dish..
Certainly the lnb arms flail about in strong winds sufficient to bend 'em off true..
rgds
VS
jpsr
1.2 channel master, cm polar mount, 12 inch actuator, Andrews feedhorn, Inverto lnb, Superjack positioner, Dreambox dm 500s, Protek 9600ip, 1m channel master with black ultra & 1m gibertini with technomate twin output lnb on astra 1/2, TM 5200 & 1000
Mullingar, Ireland
my motorized dish moved a slight bit, so i decressed my long setting in usuals to fine tune my dish.
When i installed my dish at the end of 2010 i set my long to 7.3, with all the bad weather its now down to 6.2, but it saves getting up and down the ladder and the signal quality is still the same as it always was.
I do the same, but a few tenths more and it'll all fall off a cliff.
jpsr
Mullingar, Ireland
True , i was thinking the same my self , there is only so much fine tuning can be done.
When the weather picks up i might go up and re-allign the dish, its only the east and west position of the dish i have to fix, but before i do that does anyone know the name of the strap used so the motor wont slide down the pole, because my bolts on the elevation of the dish cant go through much more spanners and also it would be a lot more easier to allign.
petediscrete
mvision hd200 combo + Technomate 5400 Super+ technomate diseqc motor+ TD110 dish
Ireland and Gran Canaria
You guys complain about the high winds knocking your dishes out of alignment.I'd say the folks around the mid-west in the States dishes are flying like frisbies along with their houses.I reckon Obama is hiding out this side of the pond till the weather passes.Puts things in perspective really.
sonnetpete
wordpress.com
Normandy, France
jpsr said:
.....does anyone know the name of the strap used so the motor wont slide down the pole, because my bolts on the elevation of the dish cant go through much more spanners and also it would be a lot more easier to allign.
I just use a suitably sized jubilee clip, the sort you fit on a car radiator pipe. Fixed on the pole, just under the motor it lets you manouver the motor to align it, without the worry of it slipping down.
Vipersan
Emmett Browns Ghost
IP9000HD +
66°East to 60°West.
2x VboxII AZ-EL
I totally aree PD ..
It is a matter of perspecive ..
I'm not complaining so much about the severity of the winds ..so much as commenting on the increased frequency with which these high winds are now visiting us ..
3 times in 5 months is a bit too frequent imo ..
And the one around christmas flattened my 1.8 pf ..
resulting in almost a month of hard graft to get it back up and functional again ..
If I had to pay an installer to fix me up every time this sort of thing happened ..I'd be many hundreds ..if not a few thousand out of pocket..
So ..I see no harm in discussing wind damage to dishes ..and the best ways to minimise the effects..
rgds
VS
